need more power
Old Jul 5, 2002 | 02:18 PM
Crazyj's Avatar
Post need more power
does anyone know how i can get cheap power outof my motor the things ive done so far im not that happy with
91 camaroZ28 convertible
rebuilt 350
flomaster cat-back
holley intake\carb
crane cam\lifters
Old Jul 5, 2002 | 02:39 PM
irocz383's Avatar
Post
When you rebuilt the motor what did you put into it?
I would do the cam and port the heads if its not done already. Depending on the cam, I would look at getting some 1.6 roller rockers.
There has been cases were the cam is too big and ends up robbing the motor of its power.
Old Jul 5, 2002 | 03:21 PM
Crazyj's Avatar
Post
the motor has a cam and lifters they were put in during the rebuild only i bought the motor i didnt rebuild it
rebuilt 350
flomaster cat-back
holley intake\carb
crane cam\lifters
Old Jul 5, 2002 | 03:24 PM
Craz-28's Avatar
Post
Exactly what has been done to the motor? Do you have an number(hp/tq) after the rebuild?
There are a number of things you could look into. Headers, 1.6 RR, gutting the cats, gears, bigger converter. It all depends on what you want to do and how much money you have.
Hope that helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, Harwood glass hood, complete Kenwood system.
Old Jul 6, 2002 | 01:01 AM
Patriot's Avatar
Post
Hey Craz ... When you put the headers on did you have to burn a new chip . Reason I'm asking is because I have a '92 350 TPI auto and I'm looking to make some small changes ... AJ
Old Jul 6, 2002 | 09:06 AM
GMTech's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Patriot:
</font>
Do you have to? Absolutely not. Will your gains be more significant if you do? More than likely. Bone stock cars will benefit from a chip change. Your best bet is to have somebody sit down and scan engine data, and have your chip burned from there, and even better if done on a dyno. "off the shelf" chips are marginal, if any benefit at all. However, I have heard good things about some of the top end chip burners like Ed Wright, but no personal experience to go by. HTH
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Jul 6, 2002 | 10:14 AM
aziroc's Avatar
Post
well, im not sure if urs if carbed or F.I., but im sure its F.I. but if its carbed.. look into that edelbrock package *that intake, heads, ect, that givews u like 400 hp* but if it is F.I. just get some new heads. Im not sure how much u want to spend... but A.F.R. 190 or 195s would be good. but $1300. or u can go with the twisted wedge heads.. they are cheaper *sorry, i dont know the price* a good lace to look for TPI stuff is TPIS.com granted they are $$ but u will get an idea of what to look for. but for what ever its worth.. my 406 is/was built by 95% of the stuff from TPIS. now if i would just get the 30# SVO injectors id be more around 440-450 rwhp and possibly above 500 rwtq *granted ill have to get another chip burned, but oh well* and the motor runs hell-a clean and gets 18-20 mpg!!
1986 IROC-Z
406 SBC TPI
399.6 rwhp 436.1 rwtq
*damn injectors running lean*
Old Jul 6, 2002 | 11:23 PM
Patriot's Avatar
Post
Thanks GMTech ... My car is stock and I want to get the most out of it without going into the motor ... AJ
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
