- Oil Question...QUICK!!!
- Throttle Body Plates-where to get?
- need help with cam number
- factory style roller cam in early "non roller" block.
- More mods
- breaking in a flowmaster
- starting trouble!
- Speaker Sizes and Sub question
- ported maf didnt work?
- rearend
- Header Question
- dash lights
- A/C controls
- Will a clutch from a 2.8L S-10 fit?
- Transmission Flush & Rearend Build
- Why does my fan wiring keep getting fried?
- HELP!! engine swap in 91 Firebird
- Car starts, then won't start, repeats..
- Where to put battery disconnect switch?
- front suspension parts
- ground effects removal on a 92
- How much for a decent paint job on a 3rd gen?
- Can anyone diagnose the problem?
- TBI to Carb Conversion questions
- Fan Switch / Knock Sensor Wires
- Oil, rats, and arms... need adivce...
- Flipping The Air Box Lid...More Sound From Engine...10 More HP???
- question about header size and performance
- question for 94ltimaro
- transmission won't shift
- afr190 dyno at 288.rwhp
- my rear brake hard line sprung a leak what should i do
- What Size Rims For My Tires
- overheat at idle?
- Looking for wheels
- Flowmaster website Question
- roller cam ?
- Carb or TPI? What should I do
- body parts for my dads 88' camaro
- were ca I fin honda "PINK"
- I blew the doors off a Honda!& im getting sued
- ZR1's on my Formula (10 pictures)
- BAD overheat
- hottest chick in an i-roc
- Almost time to Sell my
- hooker header question, on my iroc-z
- 3.42's in! whats up?
- EGR Valve
- Tapping sound from the valve cover
- ecm help!
- some question about my gear experiences
- choice sparkplugs?
- those with miniram?
- what size tire??
- F car 3rd gen roll cages
- which size socket for taking off fenders..
- different posi question
- Coil spring Installation
- Dyno Tuning
- Tubes Going Into My Headers???
- oil pressure sending unit
- Front Window stop?
- tell me all u know about front main tranny seal
- its on baby, come torque with me
- Exaust with sumped gas tank
- is it posi?
- Why resurface a flywheel?
- K&N Air Filter to Throttle Body #
- StealthRam Intake and Air Foil
- Will LT1 poly motor mounts fit 3rd Gen?
- Need Serious Tuning Advice!!!!
- 83 Crossfire Injection...
- What doors fit what?
- Flowmaster 80 series
- weiand 7525
- mini starter
- fuel pump thingy not clicking in dash
- Car backfires, please help!
- tuning tip for 2.8L
- Cowl induction or ram air???????
- IROC Z Gold Wheels 16 inch
- Racing Seats in an Iroc
- How can I make my Camaro faster?
- cross drilled + apex kevlar pads
- tbi 305
- lift?
- starting problems
- takin my 87 iroc-z out today.
- Shift Kit Question
- bottom shock bolt TQ spec? what is it?
- had to do it
- Identifing Year Of Motor
- Posi Question
- Problem after tune-up
- Bought a camaro
- l98 vs lt1 fuel consumption
- 383 question
- 3rd Generation engine
- Camaro wont start. Battery or Starter??
- roller lifters????
- Mufflex Y-Pipe
- New Rims and tires!!!!!!
- Which battery charger should i get
- head ?
- A good heads and cam package?
- How much for this ta
- stock tpi mods
- probably the most asked question.....
- It took me 5 hours...
- Hard Warm Starts
- which wheels should i get?
- Is this a decent deal on an 84?
- Knock sensor.......
- If an engines burning oil will it always be blue smoke?
- NEED answers right now! about posi unit..
- 84 Z28 will anyone sell me that plastic fin under my car?
- need help choosing
- I Just Picked Up Some Hookers
- What do you think of this setup?
- Torque Converter Question
- New Home for 350 TPI
- 84 Z28 Heater core probs? PLEASE HELP
- Flywheel Question
- Lt1
- 383/6 speed questions?
- stock vss ?
- May use rear end gears from S10- or Monte-where can I decode the axle ratios?
- West coast converter's 4 3rd gen?
- Squeek from clutch fork pivot point
- tach needle jumping
- aftermarket steering wheels
- New 3rd gen member
- 3rd gen dual fan on lt1
- manifold vacuum
- Fitment issues with headers on vortech heads in a 1982 with 700r4
- Swapping 700r4 into 1982 - what parts do I need?
- wolf car bra
- car of the month!
- im looking for windage tray/main bearing studs from ARP
- loudest/best sounding exhaust
- 3 inch duals w/2 inch mufflers
- TPI fits on any SBC, right?
- 305s w/hooker
- Found a car finally... should I buy it...
- Tripple gauge pod! Anone make them?
- header/exhaust circumference
- Weird idle
- 1985 iroc z28 350 tpi info....
- 28 Spline Axles????
- 1985 z28 1/4 mile time?
- Trobleshooting A Squeeling Clutch Noise
- magnaflow mufflers
- exhaust question
- Manifold Censor
- Rate your shocks...
- TPI conversion
- i want my car to turn better
- drop in replacement engine for 92 rs camaro
- need great/cheap heads for l98 that will make me 350 rwhp
- Do you think its worth it?
- iroc-z and z28
- extended cranking before startup
- O2 sensor placement question...
- flowmaster exhaust
- Selling Price??
- Cooling Fans
- Exhaust Question
- Rings on a 400
- how do i put on my louvers?
- Best 700 converters?
- Tranny??????
- Question about buying STB
- Camaro for the day
- god i hope i got 26 splines
- MAC Exhaust
- what is the normal operating temp?
- tranformation
- Headers
- TPI CENSOR's
- MAC SFC's on Ebay
- Some painting questions
- getting car out of storage
- where is the engine temperature being read from?
- Anybody have pics of 15x10 wheels with 5" backspacing?
- Thinking about picking up a new car
- fuel presure?
- coolant overflowing from fill bottle
- another question for aklim
- Starter lugging? kickback?
- what should i put on my t top gaskets
- How much should a 305 bare block weigh?
- Pressure building in gas tank!!!
- how do i know
- Finally got my 92 Firebird....Problems?
- damn the rain, any suggestions
- Feels good to be back, just bought a IROC
- Cam Swap in 91 Firebird Question
- pulling a gas tank from an 89 gta
- cracked and warped end caps?
- CC 306 cam in a 305?
- Which Shifter?
- i hate going to the chevy dealership
- Hypertech fan switch
- Intake/Sensor Questions
- rear end
- 2 engine power specs-which one?
- Brakes?
- Lt1 cam in L98 TPI
- fog lights
- 2000 ss wheels
- Firebird/Trans AM aftermarket hoods?
- cam identification
- sdpc engine
- Shortblock needed where to go
- Aluminum driveshaft...what is the benefit?
- 406 short blocks
- SLP's 92 Firehawk rim question
- Anyone running a 400 SB?
- spohn
- questions about my 700r4
- Tpi 383
- Heated O2 Sensor Question
- measureing tires for speedo gears
- Engine whining...
- Anyone who`s takin a T.P.I off in here
- Stock air filter swap results
- where do i find this
- what would you do?
- idear
- not sure i understand "flash" codes
- new engine what should it rev at
- free firebird!!!!!with these parts work with a 305 or 350tpi
- Paint Code...
- Rear end gear swap
- cam lobes
- tranny question
- 2 Seater 3rd Gen!?!?!?!?
- i need the greatj,s help hit me up great jay
- 305 bogging
- shift question 700r4
- SLP Headers with A.I.R
- what the hel did i do, what is normal
- Is my choke operating normal?
- Mid 80s trans am steering wheel question
- Dual electric fans-wiring and turn on.
- SLP Shorties vs. Hooker LTs.
- Fuel Pressure Regulator
- Motor Swap: Street Legal?
- bodywork
- A Heated O2 Sensor?
