Help w/ tourqe convertors
Old Jun 19, 2002 | 06:20 PM
LilJayV10's Avatar
Post Help w/ tourqe convertors
I am new to this board, I spend most of my time on 3rdgen.org. I am trying to get the most information I can about this topic because its one of the most important parts of a car. My question is this. Comp Cams, Pro Built Automatics, and some other places and they recomend a 2600 stall for the setup I am running. A 9.5 yank or vigilante is like 800 bucks, and ACT is around 600. A 9.5 or 10 is supposed to be better, lighter, easier on the transmission, and have more tourqe multiplication. I talked to a local shop about them building a 10in for around 400. The guy said that I wouldnt like it, and that I should go with a 12in, and it would be the same as a 10. I find this hard to believe. I am wanting to know your guys opionons. Should I got with a 12? just tell the guy i want a 10in, or cough up extra 200-250 for an ACT? thanks alot. I appreciate it.
Wide Open Till You See God...Then Brake!!
If You Are Upside Down And On Fire, Its To Fast.
Old Jun 19, 2002 | 07:09 PM
kmook's Avatar
Advanced Tech Moderator
Post
This is more suited for 3rd Gen Tech, moving there.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • Almost Alive: ?rwhp & ?rwtq Naturally Asperated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Jesel Shaft Mount Rockers,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Old Jun 19, 2002 | 07:15 PM
kmook's Avatar
Post
Oh i forgot! Welcome to the board!
Old Jun 20, 2002 | 12:40 AM
LilJayV10's Avatar
Post
thank you. anyone have any ideas?
Old Jun 20, 2002 | 07:16 PM
SCOTT91Z's Avatar
Post
i would also like to know, i am surprised nobody has responded to this post. i am just responding so it will be back at the top so people could see.
alphaauto
Jul 26, 2015 04:40 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GrdLockV6
Mar 1, 2003 10:59 PM
Black01_Z
Nov 18, 2002 11:45 PM
maddboost
N2O Tech
Oct 22, 2002 04:54 PM
