head gasket???
Old Jun 19, 2002 | 10:49 AM
ws6gta's Avatar
Post head gasket???
is there anything (gasket sealer,or spray gasket sealer)you guys recommend i use when i do my head gaskets?also do i use any kind of sealer on the "valley"of the block to seal the intake manifold?
thanks for any help
Roger
Old Jun 19, 2002 | 11:15 AM
angel71rs's Avatar
Post
Steel shim type gaskets need sealer. I use Permatex spray copper. Composition and Teflon type do not take sealer. I use a little RTV on intake gasket, but just around water ports to prevent weepers. Also use it on rail gaskets. Some guys leave the rail gaskets off altogether and just run a bead of RTV, but I've always used gaskets w/RTV.
Old Jun 19, 2002 | 11:58 AM
1989gta's Avatar
Post
i've had good luck with felpro gaskets. they have like a soft rubber around all the ports that seem to seal really well. plus they come off fairly easy when you dig back into the motor.
then for the valley i use felpro cork with adhesive on both sides and a little sealer at all corners.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
