- Hedmans??
- HEads
- any info on LS1 swap???
- first engine upgrade?
- Why does my 305 NEED 91 octane??
- 89 Iroc with T-tops
- exhaust manifold boltz?
- 350 Drop (Eletrical Question)
- Carb cleaner?
- Can a manual lock replace a Hatch Motor in a 89???
- lo3 to lb9
- 86 or 87 engine question
- We Bought the 88 Formula 350TPI
- n e one have a clue?
- Hatch Motor keeps dying!!
- Hi guys, I need help!!!!
- Manual tranny swap
- Car Chemistry Header Inserts?
- TPI From LB9 on a L03
- Tachometer doesnt read!!
- whould singal 3in exahust be enought
- How high compression can i go?
- Whats the Correct Timing on a 350 SB?
- Free Third Gen Camaro Interior
- cam retaining plate year?
- Fog Lights vs. Ram Air
- Rebuilt Engine
- wiring diagrams
- Injector cutting out on tbi
- Attention 88_305
- Ran good - won't restart. list of things needed please. in a bind.
- car runs like crap.... im stumped
- What temp thermostat?
- heads/cam package??
- LG4 Dying on me?!!!
- How Difficult is it to Start Up A New Crate Motor
- Tranny possibilities
- Ok.. what are the possibilities of a rearend holding 300+horse?
- New Motor Start Up Instructions
- radio wire colors
- After Tune Up Car Wont Start
- fuel injected V6 to Carbed 350
- Lg4 Questions
- Best way to get this car off the ground?
- Exhaust Questions
- Realistic Modding Potential -- LB9 V8?
- New Engine Oil Priming!!
- Increased fuel consumption after header install?
- carb issues.....!....?
- Header question
- Synthetic Oil????
- bow tie vortech heads
- Rear swap
- 87 brakes
- 305 TPI put on a 350
- Problems with 89 Iroc Z starting...
- 9c1 caprice 350 ecu
- SLP cold air induction
- LT1 Question Swap
- Crud in Engine? Use Kerosene to Clean?
- Small block chevy in mustang
- pulling a tranny, cant get 2 top bolts
- 350 swap into 305
- Intake question???
- need advice on heads, headers, cam for an L98
- This is all A/C crap right?
- 350 bottom end question
- help Engine size confused here
- Need help finding stock parts for 3gen
- Fuel pump relay?
- Removing A.I.R.
- Carb
- 1.6 rockers
- Headers come with all accessories?
- 350 TBI --- Where is the MAF?
- Speedo Gear coloring
- Open Element Air Filter
- Well motors out and disassembly has begun..
- (QDR)Driver Failed
- Help!! emissions ? about efi to carb swap
- Cam install question
- Swapping 350 TPI over to a carb
- 86 iroc header question
- HSR vs. Gears. What first?
- what would you do
- 3rd gen engine swap questions
- Turbo Info Needed
- Choosing Headers and Y-Pipe
- Welding How-To Advise and other Tips...
- electric water pump question
- Cooling Fan will not come on Need Help!
- racetronics fuel injectors...
- 91z28 after exhaust onto 91 RS (3" vs 2.5")
- Exhaust Question!!
- Question on weight loss in a 3rdgen LT1 swap?
- 93-02 seats in a 82-92 camaro
- TH350 stuck in drive?
- Code 23 with 84 L69
- will these tires fit?
- 4 Wheel Disc
- Fuel Pump question on a 91 RS
- stock fuel pressure for 88 L98
- Flow restrictions frame chassis arrangement?
- Question on a buddys car (350 TPI why so slow)
- LT1 swap headers and catback combo?
- 305 heads on a 350?
- Third Gen exhaust question
- small starter wire staying hot
- trick to change the FP regulator? TBI
- two wires to each TBI injector - Help
- HSR requirements???
- Injector size????
- 305 becoming a Stroker?
- 350 swap possible?
- TBI bolt on question or whatever
- Another head question
- Idle Compensator Sensor
- exhaust for 86 Camaro
- super charging a 91 z28
- Borla catback??
- TPI water pump question
- 350 tbi
- Exhaust sound level
- need help identifying these heads
- Overheating
- Problem number 4,261
- Oil Port Hole On 350 Small Block
- Starter Connections
- Quite the dilema here: To Cat or Not to Cat?
- Ok guys..what did i break this time?
- HELP! newbie trying to build a 383!
- 305 tbi
- Cam Help.....
- Will these fit
- 2500 to 6500 rpm on a 400 block...
- SES light
- engine problems need help bad
- These headers a direct bolt-in?
- Has anyone ran the edelbrock performer rpm roller cam?
- Deleting EGR
- Good Idea?
- auto to manual swap....
- Whats the positive side on a pigtail plug!!
- Need some help with racing rims, please.
- Really horrible gas mileage
- Speedo "Upgrade"
- Rearend Swap
- no start condition after warm-up
- wtb: 88 tpi wiring harness from pontiac firebird trans am gta
- Compressions issues...
- S.o.s.
- ls1 brake upgrade for 3rd gen
- Accel Shorty Header plugs?
- What hardware will I need?
- Installing a flex fan???
- crossmember bushings
- IrocZ swap?
- knock sensor help
- Does It Make A Difference?
- 305 TBI supercharged
- A better means of Air Intake for my Camaro..
- 200 hp out of a tbi 305 ??
- Speedo
- history channel full throttle car on ebay
- Torque Specs.....Where to find?
- Distilled Water??
- Roller rockers
- prduction numbers
- fuel pump relay
- Weight reduction
- Oil pressure!?
- Hydrolic rollers?
- Swap Help
- Problem with block heater leaking
- edelbrock intake
- Wiring Diagrams
- Block question
- Help Plz!!!
- votec intake torque specs
- how do you adjust rockers
- What's the going price for a.....
- Fuel system problem
- 350 carbed
- Help!! Alternator wont charge!
- What does the ERS mean?
- FS LT1 modded intake
- SUPERCHARGER for My "87 IROC 350 TPI
- Need help really bad
- No Fire HELP PLEASE!!!!
- TA Girdle
- Just to let u guys know..
- Better heads than my stock LG4's please..
- vortec heads i need help
- is this a joke????
- Noob here asking for help!
- S-m-o-k-e
- the 383 i want more power what should i do
- i got a heads question
- Fan switch delete?
- Reccomend a Mechanic Los Angeles
- Smog pump delete belt size-
- Stored Z 28..Loss of Oil Pressure?
- What's this for?!?!
- Coolant Temp. Sensor question-
- Slp Header question-
- Torque Specs please
- suggestions on how to make easy bolt on horse power for cheap
- long tube pics
- MiniRam Questions-
- Factory Oil Cooler question-
- help 3rd gen guys!!!
- int. lights
- engine upgrade ideas
- Carb to TBI?
- Trans mounts the same on all 3rd gens?
- 82 camaro with big block project
- Having problems with 350 replacement engine/TPI
- Removing transmission
- Anyone know where to get a replacement schrader valve for the TPI fuel rail?
- Somebody please back me up when I say that L98's had 245 hp?
- O2 Sensor
- Just Picked up an 89 IROC
- Need Help Quick
- Anyone with a 90-92 TPI car...
- Need some help finding Fog Lights
- accel 300 plus ignition
- Whats the difference between 3rd, and 4th gen catbacks?
- Runs but has issues (help please)
- High Performance Water Pump
- Will a 700R4 Tranny handle 450+ HP?
- do they make a nos system for tpi motors?
- Aerochambers or 40 series
- Ok one more "annoying" question
- LS1 brakes on 3rd gen.
- Camaro engine swap..V6 to V8, NEED HELP!!!
- New webpage
- running the 7004r without lock up
- 150 speedo?
- Gotta love TPI torque!!
- So I put in my disc brake 9-bolt rear...
- 305 question
- Need some advice
- 1LE Spohn
- Just passing on some info on autos
- wondering what kind of power these mods will make?
- I'm curious about my stock 305
- MAF to SD conversion
- Question about hoods and a carb'd 350
- "Full Throttle" IROC's go at it tonight!
