- turbos and superchargers?????
- how to wire a choke in a previously EFI car?
- IROC-Z 305 to 454 Swap!!!
- will this cam work with my stock tpi?
- Truck or Keep The Iroc???
- Exhaust Question
- TPI Throttle Body Bypass
- Real Header Experiences or stay stock manifold
- Help with a tune up
- Header decision
- Changing/Flushing Coolant
- EGR valve question
- dyno help please
- Making my Camaro... lighter please help
- The Vortec headed 350 going in my 92 Bird
- should i have called BS on this LT1 swap?
- Power Antenna Replacement
- Thermostat
- Finally got my IROC
- iroc..
- V8/v6 T-5???
- performance mods for my 91
- highway runnin on 4 cyl?
- carb help
- philly area mechanic needed
- 305-350..smog legal?
- Rattling 700R4?...
- 305tpi---> 350 tpi
- Shifter Question
- Need Help Single Or Dual Plane Intake
- 86 speedometer ?
- Lt1 and/or aftermarket brakes?
- Suspention Advice Needed!!!
- diesel effect help
- Does my car have a spare tire?
- 305 or 350ci???
- 89 fbird 305, need to remove key security
- Will LT1 pulleys/accesories fit???
- Question about Gas guage sending unit...
- Taking the panels off the door
- Car cranking slowly after tranny swap?!?
- Lookin' for any last minute advise with my heater core...
- 3rdgen down again?
- Replacing valve seals
- is thirdgen.org down again or is it just me
- 305-326?!?! 350? maybe
- Difference in Impala/F-body/Vette LT1?
- My Catalyst Converter Size
- window rain "gutters"
- Why do SBC's ALWAYS LEAK!?!
- Please help! 4 corner cooling will not allow the distributor to go in.
- Car Stalling pos. Carb Problem?
- Anybody here have a hooker cat back exhaust?
- Tpi
- Spark Plugs
- hi-po maf sensor
- Anyone wanna help!!???
- I need help with Gaskets and Rebuild sets!
- Big Problem
- When rebuilding ?'s
- Newbie Here
- winter coming and no wipers...
- stock 84 z28 and parts
- Bouncing Oil Gauge
- When I shift out of park.....
- Need some help/suggestions with the exhaust on my 92
- Damn 305's..
- 1984 Camaro
- englishtowns, slp day,
- Whats this part called
- 1992 Tuned Port Engine FS
- Headlight Flicker
- 383 finally in but......
- Transmission wont shift back into park STUCK!
- 427cid 3rd gens?
- painting
- Heads Up if you need new motor...
- What to do with the heads?
- Overhauling the 305 :)
- Cleaning the engine
- Cold Start Valve Sensor
- Need help on parts choice of a build on a 350hp TBI motor...
- Site about Yoga, meditation, relaxation, the Maha Mantra, Enlightenment and Bhakti
- autometer gauge
- Speedometer Problem
- Heres the deal
- Ok.. another stupid header question:
- What happens after the Cam install?
- Need to find Longtubes
- Whats The Best Emissions Legal Intake?
- Has anyone put a LT1 into a 3rd gen?
- Where should I start
- Cat & Muffler smoking
- Did this kill performance?
- Another exhuast question!
- help me!
- 350 TPI swap into Rock Crawler
- Paint Questions
- LT1 stock specs
- Front End Issues....Need Estimate on parts
- 86 IROC radiator shrouding
- Overheating issues, 4BBL 350
- where can I find a supercharger?
- 88' 305 TB......O2 Sensor???
- super ram question
- oil press dropping off after warmup
- Cost of Ported Heads
- Swapping Motors
- Low 13/High 12 second thirdgens
- Which size headers?
- Which cam?
- "Boxing" a frame in & a couple other ?'s
- 28in tall tire 10in wide rim clearance????
- Issues with the late 3rd gen?
- intake base help
- Question
- TV Cable
- Aftermarket cylinder heads for...
- Any tips on how to get better acceleration out of an LG4?
- 86' 305, need advice
- Bargain Deals!!!!! #2
- Which Vehicle Speed Sensor?
- 400 HP TPI Possible?
- 88 Camaro 2.8L v6 to 350 carb - Computer ?
- big block third gen??
- TPI system
- What's behind the passenger kick panel under the dash?
- New w/some dumb questions
- yup
- zz4
- Any tips on restoring sun eaten paint, without repainting it?
- Any Turbo or Supercharged LT1 3rd Gens out there ?
- 700r4 tv cable replacement
- I want to supercharge my TPI
- Anyone put a 8.5" ten bolt in a 3rd gen????
- What is it with 160' thermostats?
- oil cooler snap ring and gasket?
- slp runners
- Gen 1 carbed 383 into my bird?
- HP Estimate
- carbon buildup
- Calling all 3rd gen convertibles
- Hatch Problems
- help making a 383 stroker motor with +400 hp?
- newer nose piece on 83 z28?
- So I won some Hedman Headers off of Ebay
- My car pulls badly when I brake....
- I want to put a '77 4v top end on an '82 short block. Anything I should worry about?
- overheating
- Performance problem
- Weiand X-CELerator Aluminum Intke Manifold Single Plane
- Crankshaft
- What to use on vortec heads, guide plates or S/A rockers?
- What year or other info on this ECM
- Question about camaro heads
- 305 Vortec vs 350 Vortec Heads
- Converting my 85' Chevy truck to TPI.
- Car is alive
- Will this manifold fit my computer?
- What does EGR stand for again?
- Bargain Deals....
- Water Necks universal?
- tpi bolts?
- 383 '91 Z.....advice (loong) HSR system
- Is there a speed limiter on an 83 Berlinetta (lg4)?
- How many o2 sensors
- Nothing like it..
- What should I do ???????
- New best with the TPI
- How does the loudmouth Sound????
- Help me get my Z28 Started!!!!!
- Flow Direction of Fuel Filter?
- break line HELL
- Looking for a new Exhaust and Muffler
- Headers, and install
- Need help with a stroked sbc 350
- Torq Thruster II's
- Where are the VATS on my 92 bird?!?!
- HELP! wtf is wrong with it
- 1.6 roller rockers, is this a good buy
- mini tub???
- high 12 sec 305
- engine temp sensor?
- cheap turbo setup for your 3rd gen take a look
- Ignition module??
- Any predictions for rwhp????
- Car Audio Help
- TCC Tranny
- Are these good valve-cover gaskets?
- cut out
- Rust Showing Up
- 8.5 in 3rd gen
- How much will gears knock off in the 1/4?
- Engine almost done still have questions fro those with 350 vortec heads
- First mods for TPI??
- New car, whats it gonna run at the track?
- Is my starter on its way out?
- GM 12 Bolt Cut Down....COST???
- what are you using?
- speed limiter
- once a week
- Thinking about getting a 3rd gen
- Do I need a new rear-end?
- Umm.. Help?!..
- KANDIED91-CHP article-
- What o-rings to use with a TPIS MiniRam w/ Ford fuel injectors???
- What waterneck used w/ TPIS Mini-Ram?????
- Exhaust
- Head, Intake, And Cam Combos
- Hot Cam in l98 problems
- Flexplate diameters with 700R4 trans....
- new piston or mill heads?
- Tach is off??
- Manifold-back exhaust system?
- How much HP and TQ from a L98
- What do i have to do to fix a jumpy speedometer?
- what is the size of the stock intermidiate exhaust pipe just after the cat???
- problem after trans swap
- 3.27's or 3.70's for a TPI 350? (9 bolt)
- TPI to Carb...Please Help!
- Fuel Injectors
- Steering wheel shakes while driving
- Hypertech fan switch
- How many of u leak oil
- 88 Tpi plenum swap??
- super ram
- Question from newcomer
- Question about vortec intake manifold
- Rear Axel Seal/Bearing Q 90 FB
- fuel rails leaking
- Can I do this? Will it work?
- Brake warning light just came on...What could it be?
- "Hard to reach screw" for heater core question.
- mods for a 87z
- 4 bolt block oiling Question for my 3rd Gen
- Spraying a 2.8L Camaro... suggestions needed
- central control lock
- smogging an 1987 Z28
- L98 + super t-10?
- Put edelbrock carb on 84 trans am , question about timing advance.
- 1988 TBI Starting trouble
- Fastest Mods?
- FINALLY bought another third gen!!
- Whos runing Skinnies up front?????
- Where to find...
- Need help verifying ECM
- HEADER ?????? hooker 2460's HELP FAST
- What are the signs of a bad carburator??
- code 33, one month after code 34
- Guage cluster questions. Maybe you have the answer.
