help! TPIS afpr on a 91z 305tpi, what is best pressure?
Old Jun 18, 2002 | 09:57 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Exclamation help! TPIS afpr on a 91z 305tpi, what is best pressure?
well the headers and intake are on the car, gotta finish with the plenum and runners, etc. tomorrow. what should i set the afpr at?????
305tpi, 5 speed
tia!
taner
MY car featured:
http://www.bmrfabrication.com/Feature.htm
1996 Camaro SS A.R.E 398
11.36@120.35mph, NA
10.43@ 120.87mph N2O(i shifted 3rd to 6th,DOH!) 1.375 60'
Best mph: 132.95mph w/10.47- yes i hit 4th,lol (Sept 16/01)
oh yeah also an 80 Camaro, an 98 Ram Sport
"...i wish i was the full moon shining off a Camaro's hood..."
P.J.
Old Jun 18, 2002 | 10:04 PM
AutoRoc's Avatar
Lightbulb
Sorry for the slow responce of our forum...
stock is 45 PSI. I'd add 2-3lbs just for kicks. the ONLY way to know what is best is a day tuning at the track or on a dyno...most people tune in increments of 2 psi. take that car to a track, man! I'm interested to see some numbers. later man
Denny
Old Jun 19, 2002 | 06:55 AM
taner's Avatar
Thumbs up
thanks Denny,
i think i will start at 48 psi and see how it goes. man i had to goto an industrial fitting place to find the appropriate fittings to come off of the schreader valve.
hope to have everything buttoned up tonight, maybe even started. besides my better half is ready to castrate me.... j/k!
p.s.: thanks a whole bunch Joe for the deal on the very nicely painted headers and the tip on jacking the motor up! Gerry thought i was nuts, i think he thought i wanted to pull it out and put in another motor he knows how i get when i get going on this stuff. and thanks to Dave D for tipping me on your headers!
MY car featured:
11.36@120.35mph, NA
P.J.
Old Jun 19, 2002 | 03:18 PM
IROC Z 350's Avatar
Exclamation
Whoa Whoa now! 45 pounds is over stock for the 350 I believe. I think it was around 42 actually. Smaller pistons=less fuel required. If I recall...305s' were set at 39 PSI. Granted you have hopped up the 305 a bit but start around 40 and move it up in small incriments after test drives.
You can AND WILL go over the fuel curve and lose performance if you go too high. Good luck.
*1985 Camaro IROC-Z28 H.O. 350 A4 3.73 TPI Accel 58mm runners 24# injectors hughes 700R-4 3000 stall BFG DR's and..
*2000 Camaro Z-28 A4 3.23 MTI lid K&N Flomaster !EGR Ram Air Cutout
Old Jun 19, 2002 | 05:02 PM
Damon's Avatar
Post
Some of the early TPIs were 39 PSI (85-86). Later they switched to ~43. 48 is a good starting point with a stock chip.
Old Jun 19, 2002 | 10:00 PM
taner's Avatar
Post
thanks, i set it at 46 for now, we'll see how it runs tomorrow
Old Jun 20, 2002 | 01:28 AM
kandied91z's Avatar
Talking
my stock rating when i hooked up a fuel pressure guage was around 34 with my 350.....
although that was a little lean...low 13's i'm pushing around 38-39 and it's rich (high 11 low 12 ratio).
the only true way is to test and tune......i had it at 42 and thought it was running great until i hooked it up to a wideband and was running 11.1 and lower!!!
it would be nice if they all had a desired level to make it easy.......good luck.
jeff
KYWes
Jun 14, 2022 06:52 AM
dfarr67
Apr 10, 2015 07:44 PM
Jul 4, 2005 05:00 PM
CobraEatr
Jul 24, 2004 11:37 AM
IROC5.7TPI
Sep 8, 2002 10:48 PM
