When I turn the wheel it chokes....
Old Jul 7, 2002 | 02:41 AM
KarmaCult's Avatar
Post When I turn the wheel it chokes....
Yup, when I turn the steering wheel all the way to the left or right, it whines and then the car shakes and then chokes.
And on another note, when I'm driving at low speeds (1st and 2nd gear) it sounds like I have a flat tire, I havent heard this before and it doesn't do it in higher speeds, or atleast, I don't hear it....
Anyone know how to fix the steering wheel problem, or what it might be?
And what would cause the 'flat tire' sound?
^_^
+=-KarmaCult-=+
Old Jul 7, 2002 | 11:10 AM
firechicken_3's Avatar
Post
when yu turn all the way to one direction or the other, the power steering gearbox, shuts, closes off the passage that fluid usually goes through, so the pump has to relieve pressure somehow, the pump has a valve in it, the whining you here, is from the pump, having to use its pressure relief. its generally accepted as a bad idea to hold the steering against the stops, for any length of time more than absolutely necessary, it can damage the pump. as far as the shaking and "choking" its because when you do as i described you are dragging the pump down, and your power steering belt is gripping good enough to cause the motor to drag a little bit, usually the belt will sqeaul first.
hopefully that ends one mystery for you, the other one i have no clue
Pics of the Firebird
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
84 firebird, motorless and trannyless at the moment (was 4cyl 5spd)
parts car/race car, (at least it will be eventually)
[This message has been edited by firechicken_3 (edited July 07, 2002).]
Old Jul 8, 2002 | 01:52 AM
KarmaCult's Avatar
Post
Thanks, The only thing I'm worried about is that it didn't do it before I took it in to get an oil change, I noticed it on the way home, so could the oil change have had anything to do with it?
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
jj71787
Dec 30, 2014 02:15 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
formula79
26
Aug 5, 2002 12:21 PM
