LT1 In a 3rd. gen T/A ?
Old Jun 24, 2002 | 01:00 AM
N.W. LT4's Avatar
Post LT1 In a 3rd. gen T/A ?
Did you use your stock air box and ducting or go aftermarket?
Old Jun 24, 2002 | 11:28 PM
phoenix916's Avatar
Post
I personally used a 93 LT1 which didn't have maf so I just bought a slide on K&N from howell-efi $100.
Old Jun 25, 2002 | 10:35 AM
Zepher's Avatar
Post
I am going to use a custom 4" Intake pipe.
http://www.donpagevideo.com/pics/lt1/cai_02.jpg
I am also converting to Speed Density to eliminate the MAF.
1986 Trans Am WS6
LT4 350, LT4 Hot Cam, T56, 52mm TB, MSD 6A & Blaster 3 Coil,
LT1 3.42 Posi/Disc Rear, Lakewood LCA's & Adjustable Panhard Bar,
Eibach Lowering Springs, 17x9 WS6 Wheels, T-Tops,
Custom 4" CAI w/ K&N Filter, 160*stat.
Autometer TriplePod with Phantom A/F & Boost Gauges.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph This was with the LG4 carb setup.
WS6 Trans Am.
Old Jun 25, 2002 | 10:37 AM
LT1Powered85Z's Avatar
Post
Stock TPI air box with a '91-'92 Speed Density bellows.
I'm not using a MAF either...I'm running SD.
Eric
Old Jun 25, 2002 | 10:43 AM
N.W. LT4's Avatar
Post
I've got too much money into PCM tuning to go to SD.
Roadie
Feb 16, 2015 10:34 AM
ChrisFrez
Feb 15, 2015 07:49 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ChrisFrez
Dec 21, 2014 09:47 PM
formula79
23
Jun 20, 2002 01:42 PM
