Clutch replacement
Old Jun 20, 2002 | 04:39 PM
gmackZ28's Avatar
Post Clutch replacement
Do you always have to resurface the fly- wheel when changing the clutch? If you don't then what?
Old Jun 20, 2002 | 05:35 PM
irocz383's Avatar
Post
I don't know a whole lot about shanging clutches since my car is auto, but... I beleive that if you don't resurfcae the flex plate you'll cause the clutch to slip.
I'm pretty sure its the same idea as brake rotors. Pulsation, noise, and grip power all become a factor if not resurfaced.
Old Jun 20, 2002 | 09:24 PM
TRVLIN99's Avatar
Post
When i had my clutch replaced by a pro shop, they said it is standard procedure to resurface the flywheel. If not done, any "run out" will cause the clutch to grab or pulse during engagment. ( Just as with brake rotors.)
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
