Distributor Brace Bolt Size?
Old Jun 26, 2002 | 08:18 PM
CaysE's Avatar
Post Distributor Brace Bolt Size?
I'm trying to replace the engine oil pressure switch, but I need to lift up the distibutor to get the socket wrench in there. Anyone know what size the distributor brace bolt is?
1984 Camaro Coupe LG4 V8 (5.0L 305ci)
  • K&N Filtercharger
No more stock!
Old Jun 26, 2002 | 08:39 PM
stevem's Avatar
Post
it is either 9/16 or 15mm. there is a special wrench for that.
Old Jun 27, 2002 | 12:58 AM
CaysE's Avatar
Post
If you mean there's a special wrench for the oil pressure switch, i got a socket that fits it: 1-1/16" As far as the distributor brace bolt goes, if it needs a certain kind of wrench, let me know. Otherwise, i'll try out those two sizes. Thanks
Old Jun 28, 2002 | 07:29 AM
hotrod1984s10's Avatar
Post
stevem is correct. The bolt is either a 9/16 or 15mm. There is a special wrench to ease the task of loosening, or tighening of this bolt because of its obstructed location. The wrench looks like a miniature hockey stick, with the blade portion being the box end of the wrench layed flat. Different engines, different style wrenches. Mine is from snap on, but you may be able to get one from a parts store, or borrow one.
Old Jun 28, 2002 | 12:42 PM
Damon's Avatar
Post
It's 9/16". You can get it loose without a distributor wrench (use a combination box wrench and take the skin off a few knuckles) but it's much easier with the right tool.
Old Jun 28, 2002 | 10:09 PM
ws6gta's Avatar
Post
i used a crows foot and an extension. 9/16
hope this helps
Old Jun 29, 2002 | 03:02 AM
CaysE's Avatar
Post
Hey guys, thanks for all the help. It was a bitch to get a good grip on the bolt with a regular 9/16 wrench, but it worked. Plus, I kept all my knuckles intact. Unfortunately, I screwed up a bit taking the dist out. Please check my newest post "Please HELP! Distributor won't go back in correctly..."
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 11, 2015 03:47 PM
