which mod should i do 1st intake or exshust
Old Jun 20, 2002 | 05:51 PM
Chris`s85Z28's Avatar
Question which mod should i do 1st intake or exshust
Well I have $1500 Canadian to spend on my Z28 it allready has a cam and headers 1 5/8" headman so should I do a true 3" exshust like flowmaster or get a intake and carb?
R.I.P Dale Earnhardt 3 Nascar isn`t the same without you
1985 Z28 My pride and joy
LG4 305 5spd T-tops 3:23 posi 3" exshust mild street cam Accel wires shorty plugs cap rotor and a H.E.I super coil FINALY GOING ON THE ROAD MAY 24 after a year owning it
5.0L BEWARE
http://Chevy-Camaro-Z28.CZ28.com
Speed limits Whats that???
Kills 1/0
Old Jun 20, 2002 | 06:21 PM
ZBRA's Avatar
Post
How much is $1500 Canadian?
'94 Corvette Admiral Blue
-==ICON Motorsports==-
Old Jun 20, 2002 | 07:11 PM
Post
probly $800
and also I was looking at the compcams magnuim roller rockers there like stamped steel ones but they have a roller on the tip there is 1.52 and 1.6 I want the 1.6 for the 305 says they are good for 15-30hp the cost $371 (candian) ouch are they worth it?
5.0L BEWARE
Kills 1/0
Old Jun 20, 2002 | 10:48 PM
IrocSS85's Avatar
Thumbs up
I think youd be best to get the carb/intake. it will save ya some weight, be cooler cause alum. will dissapate more heat, and get great throttle response. get a 600 carb though, dont get the 750. itd be too big.(just in case you were thinking about it) you'll need a normal dist. too though, cause your old one is comp. controled I think.
what size cam do yo ugot in there? a mild cam made for a 350 will act like a bigger cam in your 305, so dont go too big w/that either.
chris
1985 Iroc Z, (parting out, email for parts)
1986 Iroc Z, (up and running, but still lots of work to do)
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solid cam .501I .510E, 4gen rear w/3:73posi,girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd :6al, coil, dist., mallory wires. exp high 12's-low 13's
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Jun 21, 2002 | 09:30 AM
Jim85IROC's Avatar
Post
Dual 3" exhaust? On an LG4? Dude, a stout big block doesn't need dual 3" exhaust. A single 2.5" pipe will suit the LG4 just fine. Spend your money on an intake manifold and a cam. The stock quadrajet can work fine with a little tuning. The big restriction in the LG4 is the cam and low compression. Can't do much about the compression, but at least you can put a better cam in.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Jun 21, 2002 | 01:35 PM
IrocSS85's Avatar
Post
well jim, he said true 3" system, not true duals. prolly just didnt read it right. I have to do double takes all the time.
as for the compr., you can do a little. take off heads, have them milled and ported and use head shims instead of gaskets. should be able to raise the compr. .3-5 i believe.
he already has a cam, but he didnt say what kind of cam. whats the specs? that quadrajunk is prolly ok for your power level (and alot higher) as long as its working ok. but if its not working right, scrap it and get a holley.
just my $.02
chris
[This message has been edited by IrocSS85 (edited June 21, 2002).]
Old Jun 21, 2002 | 04:44 PM
Post
I have no idea what kind of cam it is I bought the car with it in allready I want a single 3" exshust not duals was thinking intake and card I was thinking the Edelbrock performer EGR intake with a 600 or 650 holly or 625 road Demon and also should I port my heads or buy the vortec heads or some other kind
5.0L BEWARE
Kills 1/0
Old Jun 21, 2002 | 06:35 PM
CamaroZ2885's Avatar
Smile
About the heads I would go with the Vortec heads. For $800.00 you could get a set of them. They are like $230.00 each so it would wind up costing you like $500.00 Max!! Go to www.Gmgoodwrench.com and select the dealer Friendly Chevrolet. They sell the heads for the cheapest and they are completely assembeled. I think that would be alot better than porting your heads or so Ive been told. Thats what I would do if I had the money. But its up to you!
Adam
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
