- Ignition question...
- Kid from school bought an IROC...
- Headlight conversion
- 383 hp numbers ?
- Interior trim help please.......
- how to find cam specs...
- which is easier?
- Quesion about a 87 IROC
- How to remove the seat belts
- How much should I offer for this tranny
- headlights
- lowering
- something's up with the car...
- Questions About My '90 IROC-Z...
- 700r4 Dimensions?
- Anyone with a Megashifter
- Heeeeellllppppp!!!!!
- billet grille for 3rd gen?
- factory rim/wheel paint
- engine stalling
- Hey everyone, new here
- small blocks interchangeable on the outside
- Starting problems now
- Emergency brake problem!
- Smog-legal question
- what do you think?
- Other than the stroker crank what do I need?
- headers, i hate these post too
- suspension whats the best?
- What is the best way to repair holes left after spoiler remover?
- Puncutured the Radiator
- Need help with hotcam kit ASAP please!!!!
- Torsen?
- Pull down latch mechanism - Help!!!
- 305 TBI to 350 TPI
- Fluids
- whats up!!! new to the board...
- Fuel filter change - mess
- Magnaflow on a 3rd gen...anyone?
- idle problem....
- cam and intake help
- oops. hehe
- is this posible???
- Fuel filter replacement
- yeah so
- Wheres a good place to get a turbo 350/400
- Upgrading rear brakes
- HELP....buyin 82 berlinetta and i need some help!!
- Another Rear End Question...
- Rear shocks-upper bolt
- Im out of ideas...please help...runs rough/engine backfire
- Buying second 3rd gen! Appearance questions, LS1/M6 swap questions
- Whats the first thing you would do...
- need some tech help
- HELP EGR?, TPS? Check engine light on
- jack up the back
- Which Shift Kit Should I Get?
- heater core
- Tires
- miniram owners...
- Rain is not my friend
- Which engine would be better?
- Differences between LT1 and tuned port throttle bodies?
- ls1 spindles on 3rd gen?
- somebody gimme sum info
- exhaust stink
- 1981 berlinetta
- k-member swap
- 305 to 350 on CFI Z28
- 350 swap...my fuel pump has no power...
- corvette to camaro driveshaft??
- Getting a little further with the window problems
- Sticking EGR?
- Leak
- New steering wheel...air bag ??
- trim panel fasteners---hatchback area
- F-body Engines
- Fuel Pump Just Went!
- Bad IAC?!? How can I tell?
- C.a.i.
- Gas smell and Tach Problem...need help!
- FYI, Vortecs + Edl Performer + carb = Don't clear stock hood.
- HELP!!!!!! failed emisions very badly!!!
- 383 stoker for an 86 camaro
- when changing ops
- Automatic to Manual transmission switch
- 2 relatively easy questions
- Injector issues
- Question
- Need part #
- Help please..I got spray paint on the console of my 92, can I use paint thinner..
- LT1 Cam Specs
- Where to start?
- 160 or 180 thermostat?
- Pics of my car
- took care of college, now I'm back..
- What is the best intake?
- Cylinder Heads !
- OMAHA PICTURES-needs 82-85 for commercial shoot asap in Los Angeles
- Carbererated idle adjust???
- Radiator Flush?
- 1987 white iroc-z for sale
- electric hatch
- holley stealth ram?
- Shocks and struts?
- What's the truth about headers & free flow exhaust ?
- cam info
- Vette servo
- Corvette Seats?
- What is this one worth
- LCA bolt size?
- Recommended tairpressure?
- Iroc-ss
- Question about slicks...
- Anyone running a roots blower in their third gen???
- Check oil light coming on
- Torque Arm Mount (T56 Swap)
- 92 Corvette 6speed in my car?
- figuring out future plans.
- 2000 vette T56 Direct Swap???
- Free Mods for a 1990 IROC-Z 5.7
- Any one Wanna Buy An IROC-Z?
- What CC head? and help me decide on new parts!
- timing..pinging ??
- Rear end....
- carberated on 3rd gen?
- Just won Black Leather interior on Ebay.......
- tranny acting funny? not completly sure...
- I know its not a supercharger, but....
- What is this? (found in the door)
- Positive Traction Differential
- Anyone know a where I can buy a Lexan windsheild for my 3rd gen?
- Exhuast scraping noise
- Need help figuring this out!!!
- fans not coming on?
- Damn Alternator!
- Sorry guys....
- Help!
- Sick of those Five-O Stangs
- Where to get a nice cowl hood?
- help me my *****s
- Supercharging my V6
- New Pics
- Rocker arm broke, why?
- Im picking up bad vibrations
- Theft Prevention
- stock pan enough room for 383 crank?
- How can you tell if the engine is 305 or 350?
- 2 or 4 BOLT MAIN ???
- Transmission ?'s
- Door panel problems
- tpi sensors
- tq converter going out?
- 194 heads(roller rockers)
- duals?
- I need suggestions for a 350 project!
- Fastburn heads any good?
- IROC ZF - What the hell is it?
- engine problems
- flowmaste exhaust
- 3rd gen vs 4th gen
- Parting out 88 iroc
- Transmission swap
- a/c blows cold mist
- Rear-End
- RIMS..... looking for 17"... suggestions?
- Do hydraulic flat tappet cams make power?
- Overheating with my A/C on in traffic
- help with fender problem
- Feedback to Edelbrock carb
- Stock shift points on a 700r4
- Block Numbers
- will the door from an 82 Z-28 work with my 92 RS
- lt1 for 3rd gen
- Headlights died? AHHH HELP
- Guys With 4th Gen Console, Gotta Question..
- aftermarket build up
- alternator current baseline
- is the air cleaner element for the H.O.
- Swaybars
- need help car wont stay running!
- thirdgen
- stock lt1 starter on 350 swap?
- Motor swap, what works?
- aftermarket steering wheel
- Fan Switch
- Shift Kit?
- How to Carb My TBI?
- hooker long tubes
- L98 or LT1
- quick question...how many cca
- SFC's and Headers
- '86 to '92 Conversion
- Wondar bar/steering box brace
- jump starting
- How much would you pay for this ride
- Need pics of installed sfc's fast
- egr
- Need to buy a 3rd gen - which one?
- Tell me about my 92 RS, please
- Motor not starting!
- 305 TPI, oil sending unit, thermostat, tach....
- engine swap
- water temp gauge not registering
- Seems liek theres nothing better than tranny problems
- Ignition Problem
- Damn Car (Semi-Long)
- Big Question here
- leaking rear end seal
- going with vortech heads kit
- Engine Panning help
- which is better
- Trasnmission Problem
- 81 Malibu... sat 3yrs! How to bring it back to life
- 91 Camaro-VS-91 Trans Am
- Fuel Pump??....Im stuck out of town kinda urgent
- FS hayes repair manual
- 92 camaro
- Midas Ravin Z33 Z55 Z77 Mufflers
- cam
- Parting out 91z28
- Alright help me out with this lame instalation
- two questions on IROC
- need DART Pro 1 head #'s
- 383 build(plans), need suggestions
- 80,s vette
- front suspension (adj struts)
- Air Intake Duct?
- LS1 exhaust on 3rd gen
- msd ignition
- Turn signal question
- Question about Headers
- L31 Vortec Pushrod length?
- i hate t5's
- Handling like a C5 .... or at least a C4?
- LS1 in a 3rd gen
- th350
- Piston and pin offsets...
- Wrecking yards - those F'ERS
- need 350 dual cat exhaust pic
- What size connecters?
- Oil Gage
- little pic??????
- Throttle Body Spacer
- Best Rust Killer
- Length (time) of T56 install
- Guys That Hvae Motor Knowledge Inside Please....
- ignition module
- stock spring rate of my 91z?
