Crack and Pop at High RPM's.
Old Jun 25, 2002 | 10:16 AM
91Bird305's Avatar
Question Crack and Pop at High RPM's.
When I took my car out this morning and got it on the road I took it above 3000rpm and the thing started popin at the higher band. I can't figure out what would be causing this. I lowered my fuel pressure to 14psi and I am getting an SES light but I haven't checked for codes yet but I will when I get out of work. Any ideas what this would be? Thanks.
1991 Firebird 305
Eric Natzke
"It ain't Stock"
http://members.aol.com/j007golden/91firebird.html
Old Jun 25, 2002 | 02:35 PM
IROC Z 350's Avatar
Lightbulb
14 psi? Is that a TBI car? (throttle body injection) ..because if you have TPI 14 psi is way too low. I think the 305 TPI motors were set at 39.
Regardless, if your fuel pressure is too low the engine will lean out and detonate.(ping, sputter, cough)
*1985 Camaro IROC-Z28 H.O. 350 A4 3.73 TPI Accel 58mm runners 24# injectors hughes 700R-4 3000 stall BFG DR's and..
*2000 Camaro Z-28 A4 3.23 MTI lid K&N Flomaster !EGR Ram Air Cutout
Old Jun 26, 2002 | 08:59 AM
91Bird305's Avatar
Post
Its for TBI. So 14psi is 4-5psi above stock. But maybe I need my fuel injectors cleaned or something. I will try setting it forward just a little bit and see what happens.
1991 Firebird 305
Eric Natzke
"It ain't Stock"
Old Jun 26, 2002 | 09:01 AM
91Bird305's Avatar
Post
I also have a brand new fuel filter I should install. That might be my problem to, you think?
1991 Firebird 305
Eric Natzke
"It ain't Stock"
Old Jun 27, 2002 | 03:38 PM
IROC Z 350's Avatar
Smile
Hmmm. Could be. I know I need to replace mine. I 'm actually having nearly the same problem right now....but my car was in storage for a year and a half. I think there is still some bad gas in the tank. Time to drive it out.
Old Jun 27, 2002 | 04:04 PM
AutoRoc's Avatar
Lightbulb
Maybe back OFF of the fuel pressure a little. MAYBE it's possible that the injectors are locking yup because of too much pressure. Tis possible grasshoppaaah Goodluck!
Denny
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
hotrod 5210
Dec 22, 2014 07:28 AM
