How do I tighten the slack in my steering box?
Old Jun 20, 2002 | 10:11 PM
IROC Z 350's Avatar
Question How do I tighten the slack in my steering box?
My IROC (recently out of storage and running!) has a good bit of play in the steering linkage. It has a relatively new coupler on it. I heard I can tighten up the slack by making a couple turns on some screw on the box itself. I took a look and think I may have found it. Can someone help me identify if this is thae bolt I need to turn. It's in the top middle of the box. Also it seems to have an allen bolt on top of it. Turn that or the bolt....or what?
*1985 Camaro IROC-Z28 H.O. 350 A4 3.73 TPI Accel 58mm runners 24# injectors hughes 700R-4 3000 stall BFG DR's and..
*2000 Camaro Z-28 A4 3.23 MTI lid K&N Flomaster !EGR Ram Air Cutout
Old Jun 20, 2002 | 10:37 PM
IrocSS85's Avatar
Post
thats the one alright. but, do it little bits at a time. you only need to turn it a little bit. if you make too tight, you can ruin the gear. just turn it till the strg. feels tight and responsive again.
hope this helps.
chris
1985 Iroc Z, (parting out, email for parts)
1986 Iroc Z, (up and running, but still lots of work to do)
355, ported camel hump heads,750 holley, 700r4, 10.5 compr., forged flat tops, solid cam .501I .510E, 4gen rear w/3:73posi,girdle, and disc's, Edel. torker II, shift kit, 3500 stal, hedmann LT. headers, 4 gen seats, man. strg., lt1 starter, alum. w/p, msd :6al, coil, dist., mallory wires. exp high 12's-low 13's
1995 z28,SS Hood, Iroc style spoiler, tints and black outs, 700r4,2400 act. stall speed,B&M hammer shifter, 17" budnick trilogy III wheels, 275/40 ZR17, 160 stat, man. cooling fan sw., homemaid CAI,1LE elbow, hypertech airfoil, t.b.bypass,!cat, flowmaster, !maf screen, relocated batt., 1LE front l.c.a.s', poly trans and torq.arm bushings, MSD 6AL, custom program, p&p maf, accel coil, and under drive pulley
mods that i have, just not on car yet:
msd wires, edelbrock mid. headers, edelbrock rpm catback
Old Jun 20, 2002 | 11:21 PM
IROC Z 350's Avatar
Smile
Cool. Thanks. I'll give it a turn and see what happens.
Old Jun 21, 2002 | 01:12 PM
Damon's Avatar
Post
I do it kind of like a wheel bearing. Tighten 'till you feel it bottom (don't crank it super tight) then back off about 1/2 turn. I've taken as much as 2 1/2" turns out of some really old steering boxes to get the slop out!
If the steering feels "sticky" while driving after performing this procedure then you've gone too far and need to IMMEDIATELY take it back home and back it off some.
Victor Lamb
Aug 26, 2017 02:52 PM
sseeya
Apr 9, 2015 06:38 AM
edman
Jan 25, 2015 02:41 PM
CaRParts102
Dec 6, 2014 08:45 AM
