80psi on my oil pressure, help!
Old Jun 21, 2002 | 05:19 PM
IROCU69's Avatar
Post 80psi on my oil pressure, help!
Ok I had to change my valve covers from the high rise M/T ones I had to the stock TPI valve covers so I could use the 89-92 serpentine setup. There was an oil leak at the gasket so I changed the gaskets on the covers and that stopped the leak, however I added the oil till the dipstick said to stop and now the car runs at 60psi at idle and then 80psi during acceleration. Whats up with that? I'm not driving it as of right now till I figure it out because cant that high of an oil pressure damage the engine?
-Mike
Old Jun 21, 2002 | 09:24 PM
Stephen 87 IROC's Avatar
Post
It won't damage the engine however it may force itself out some seals such as the rear main.
Don't rely on factory gauges. If in doubt, install a mechanical gauge to check the pressure.
If you're really worried about it, use a lighter grade of oil. If it's only high when the engine is cold but drops off as it warms up, don't worry about it. Change your PCV valve while you're at it. Maybe your crankcase pressure is high and it's being forced back into the oil galleries (not likely but you never know).
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 115.91
Best corrected ET: 11.114
Altitude corrected rear wheel HP: 457
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
Old Jun 22, 2002 | 01:33 AM
IROCU69's Avatar
Post
Well heres a little background and what I did earlier today. I have a 74 350 bored to a 358 in my 85 Camaro. Its fairly built and its got a large cam, Comp Cam 305H, 253@.50, and 525 lift int/exh. I have a mechanical gauge in my car right now thats why I was worried. I changed my oil as well putting in 5qts of 5W30. The car still runs a 60psi at idle with the 80psi on acceleration. I dont run a PCV valve either. What could cause this??
-Mike
[This message has been edited by IROCU69 (edited June 22, 2002).]
Old Jun 22, 2002 | 06:03 AM
fast89rs's Avatar
Post
you should be running some kind of pvc setup. pvc one side vent the other. lowers crankcase pressure.
1989 Rs Camaro. Previous 2.8, 327CSB bored .030 over. Forged internals. Worked double hump heads.edelbrock 600cfi, performer intake,14x3 edelbrock sig. series AC. Malory 3 port AFPR,shorty headers. 3" dynomax, no cat.700r4 rebuilt, transgo reprogramming kit, 3000stall, B&M megashifter
Old Jun 23, 2002 | 02:17 PM
IROCU69's Avatar
Lightbulb
Well whatever the case... I ended up driving it down to University Ave (downtown Minnesota) for the back to the fifties show. Well the thing started out at 80psi, but then as I kept driving it fell back down to 60psi. Dont have a clue what that was about, but its where it should be now so I'm not going to complain.
-Mike
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
