Clunking noise
Old Jun 28, 2002 | 10:13 PM
punisherZ28's Avatar
Post Clunking noise
When I give it half throttle or more off the line, there is a loud clunking sound under the front passenger footwell. The transmission and all related parts check out okay. Any ideas? Thanks
Old Jun 28, 2002 | 11:27 PM
phoenix916's Avatar
Post
If you checked the tranny mount and it's fine you snapped a motor mount.
Old Jun 30, 2002 | 08:20 PM
Post
If the motor mount is snapped wouldn't the engine move around if I put it in gear and tap the gas while holding the brakes? It doesn't.
Old Jul 1, 2002 | 10:23 PM
phoenix916's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by punisherZ28:
</font>
Sometimes yes sometimes no. When your holding the brake the motor won't flop as easy. Jack up the tranny and see if there is any seperation on one of the motor mounts.
Old Jul 2, 2002 | 09:02 PM
Post
I jacked up the transmission and the whole car starts to raise, so I think the motor mounts are good. The sound is a clunk, and then if I keep it floored, it buzzes. Could this be from the exhaust system being bent and hitting the floor pan?
Old Jul 2, 2002 | 09:48 PM
phoenix916's Avatar
Post
The whole car will raise. Did you disconnect the tranny mount? All you have to do is jack it up a little and see if the space on one mount is bigger than the other. It could be your y pipe or something but if it never did it before that would take you back to motor mount. I can't believe noone else has any suggestions.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
