- 350 SLP TPI Headers on a 305 TPI???
- Biggest tire on 16" '86 z28 rims?
- Help! Fuel pump won't shut off
- 87 Iroc AIRBOX modification
- What will i run 1/4 mile?
- Check Out My 1992
- 1989 Camaro RS Burnout
- cat back
- T56 swap into 3rd gen
- 3rd gen buyers guide
- 91 RS 305 questions
- Transmission Type?
- PCV and oil consumption...
- 250HP from a 305TPI???
- Mass Air Flow
- LT1 Heads: Accessories Q?
- Proportioning valve
- disc brake conversion kits
- 350 TPI rebuild kits?
- Since I have my ECM sitting on the floor
- Tire question
- At
- Sanderson
- Here's a Pic, where to remove the break pads?
- How to stuff a Olds 400 where a Chevy 305 used to be
- HSR purchase
- Take a look at this Chassis.
- 1991 Camaro Z28, a steal??
- Updated L98 Progress Page
- Single fan to dual fan,any difference?
- olympics edition ???
- Trans Am rear end
- what to do please hlp no more garage
- Effects of not having o2 sensor
- LT4 hotcam legal on L98 in California???
- Help with idle problems
- Injector Tapping
- doesn't warm up
- building 350 for my camaro
- 700r4 speedo bounce-electric
- '91 Z28 305?
- goin crate??
- cowl hoods
- 2nd Gen threads on lugs the same as 3rd Gen?
- tranny
- putting a rack and pinion on a 3rd gen
- Do SLP headers # 3001C have....
- 385 fastburn
- Start naming your 12 second 350 combos....
- 12 bolt
- stalling out
- 89 Iroc-z convt.
- my car sits an inch higher on one side!
- My car is having problems. Help would be greeeaat.
- Need to upgrade Chasis - Need suggestions
- $1200 to spend
- difference between v6 and v8 models?
- Which heads to go with?
- Installing Hurst Shifter
- ricer math.... sorry
- Exhaust Fumes
- unibody
- Air cleaner hood clearance
- Firing Order on big block
- Motor Mounts
- Steering wheel swaps?
- Quick!!!!!!
- Can U Put A Big Block In A 1987-1982 Camaro
- 3rd Gen Blackouts, PLEASE HELP!
- 92 RS 305 tbi won't start
- Looking into Domestic...
- looking to buy 3rd gen camaro to "build", which year to get??
- O.K. Time for the LT1/ Any good links?
- Nice Suprises found during L98 extraction
- l69 dual intake air cleaner ducts..
- What do you guys think?
- Transmission trouble..
- Weird ZZTop IROC
- A/C Heater Controls
- rear ends???
- rear axle bearing seals
- headers
- t-top leakage
- comp cam
- flowtech headers
- 3rd gen to 4th gen rear end swap
- wiring harness help
- dash removal
- berlinetta digital dash swap
- considering.?.?
- I think I found the problem - the computer
- Which Tranny?
- Injectors 22lb or 24lb????
- SLP Cams
- my Z is runnin like sh*t
- Where to get Victor JR intaked flowed
- T-5 vs T-56
- Limits to the TPI intake system
- Fuel Injector sizing calculator?
- Is it a 350? or not
- Longtubes better and cheaper than hookers?
- 305 to 350
- Gears
- LT4 notHot cam?????
- Cam info requested....Which one, which one??
- E CutOut
- How long to change front brake pads?
- Subframe
- different rears for 3rd gens?? (10 bolt,9bolt,etc.)??
- weld draglites
- how do u disable speed limiter
- Darn Exhuast Leak
- changing rocker arms effect vacuum?
- V6 to V8 swap. what's involved?
- Fault in Quad Driver Module
- is it possible
- steering column trouble
- quadrajet
- Where is the ECM grounded
- another engine question
- 305 to 350 what parts
- plug wires
- Adjusting TPS on a SD ECM
- broken rocker stud
- This Cant be....
- ram air vs. cold air intake
- cheap hp&trq???
- Carb or fuel injecion
- Transmission Question
- Need Cam advice
- How much would a LT1 3rd gen be worth?
- Tranny compatibility question
- Water Temp Gauge Question?
- Folks running with 383 strokers....
- 305 to 350 tpi
- Trany Lines
- Best way to tow a third gen
- TH 400 Help
- Transmission leaking fluid!! Please Help!
- What is the HIGHEST HP you have seen come from a 305 block?
- What should I do?
- Times after mods.
- How Do I Bypass The Smog Pump?
- Electric fans
- What Sized Throttle Body would be best for my 305?
- Cruise Control swap?
- lets pick out a cam
- got my latest z28 today
- summit dual exhaust
- 1987 IROC Z/28 RPO codes? is this a 1LE?
- It's bout the fans.......
- Chassis evolution?
- Does this really work?
- Anyone here have Borla?
- shorties and y-pipe
- carb & intake swap
- how to get BIG power from an L98
- SLP header problem...something doesn't add up-
- afr heads
- 87 to 88 on up drive belt swap?
- Ignition stuck on 89 IROC.... anyone have similar probs?
- Will these fit my car
- Hedman Headers
- Question on brake job.
- Question about T-Tops
- LG4 POWA FO YA FEWL! (vid of Z28james's Z)
- Can I fit 275/60r/15's on 15x7 rims?
- 90 FB headlight motors
- Question on Torque Converter stall speed for MiniRam
- Oil Pressure Sending Unit
- 87 camaro gauges
- 350 TPI Fuel Injectors
- Where can i get the locking lug key?
- Is this right?
- Does anyone have any clear pics of
- why is the ground strap getting really hot
- LT1 intake on 350tpi,what do I need?
- EGR Valve
- roll cage?
- cam question
- ECU with LG4????
- iroc-z tpi on a 350
- Firdbird Lights =====> Camaro Lights
- i'm new here...
- Please post you sound clips
- what year did the SBC go to the 1pc rear main seal?
- Supperram users
- which manufacturer??
- stock times
- vindication!
- I'm blowing fog/headlights out...voltage regulator?
- interior
- modding up a 8.5" rear end
- Power Steering Pump Pulley
- trans swap
- LCA relocation?
- SFC Install
- Best 350 short block crate motor
- Skinnies Up front
- How to route belt after AC + Smog pump delete
- Have - Stock 88 F- Body 305 Want - 350 Horsepower
- Check engine light on camaro
- Dual Exhaust
- Rear End Gear Change (G80)
- Big Block
- What rim & Tire Combo are you running?
- engine swap
- Any reason I can't use rubber fuel line hose as part of the fuel pickup in the tank?
- Mystery Vaccume lines
- 2 questions.........
- Ignition upgrades
- 3rd Gen Weight Reduction
- much help needed
- Fiberglass Replacement Fenders for street
- Anybody else ever tried this?
- back fireing
- why do you even drive this junk
- 1991 Zr1 Z28
- Performance Upgrades
- Good Place to buy a 3rd gen?
- Surging at low speeds/gas smell
- Car Only Runs When Starter Is Cranking
- This is ridiculous, I'm getting 7MPG...carb 350 help.
- Idle starts at 1k, slowly rises to 1.5k
- Taking off the front bumper cover.
- Manual to automatic
- SD Systems still have a MAF right?
- Which Tires??
- Cold Air Intake
- Any difference between the 2
- How much horse does a LB9 have?
- LT1 in 3rd gen
- dual exhaust????
- First Time RS Owner Here.
- anyone use a trans star torque converter?
- Gas Tank / Fuel Line Dilema..........
- Aluminum Panhard bar ??
- What do the brake pads susposed to be...
- Flat tappet and (factory) roller cam interchange possibilities- THE REAL ANSWERS
- Electric choke adjustment + Crappy gas mileage.
- Exhaust pipe size
- Stock T-5 shift knob thread?
- synthetic ATF to slick for clutches?
- which carburetor
- Almost bought an 95 Z yesterday.....
- Rookie Question
- Camaro I might be looking at, opinions?
- Odd Problem
- warm air, no heat
- PAINT REMOVAL from bumper
