PDA
View Full Version : 3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Vavle Covers
  2. Hood Louver Removal?
  3. 305 TPI to ZZ4 Stealth Ram 350
  4. insurance Q
  5. Swapping in a new differential
  6. 275's on my iroc-z?
  7. MAC Subframe Connectors?
  8. rims on 85 t/a
  9. L-98 vs. LT-1 .. 0-60
  10. what is the CFM on a stock 90 model TB?
  11. snow is around the corner. is your winter beater ready?
  12. 88 trans am???
  13. couldnt score the heated garage, car sittin in woods
  14. where's the closest event to san jose
  15. Speed Density guys.....
  16. 700R4 Non Computer Lockup kit
  17. 85 TPI not right after rebuild, lots of questions!
  18. Sun Pro Gauges?
  19. hp junkie!
  20. Taller centerbolt valve covers....can you get them?
  21. fuel pump q's
  22. Paint On Bumper & Fender?
  23. AFPR Question
  24. whole mess of 3rd gen questions
  25. Cracked Oil Pan!
  26. 3RD gen with LT1 want Supercharger
  27. "Early Style 202 Heads"
  28. Possible Clutch slippage or grab?
  29. leaking coolant *help*
  30. Catalytic converter?
  31. Tire Recommendations
  32. brother wants to trade edelbrock performer rpm heads for L98 heads and TPI.....
  33. Who has the fastest 305TPI?
  34. Will I EVER learn to quit...lol
  35. Engine Swap Troubles
  36. what is a pony cam!?
  37. What Belt Size Do I Need?
  38. the popping is driving me crazy please help 86 Z28
  39. slp injectors??
  40. Cabin air filters in 3rd gen?
  41. Enormous Rattling!!!!
  42. Should i swap my stock 305 for a 350, or buy a 2002 SS?
  43. Polishing aluminum rims with clear coat
  44. Huge Traction Problems (tires I think)
  45. 91-92 gage cluster
  46. Longtubes for my TPI
  47. ford 9" for sell
  48. T5 VSS doesn't want to go into T56...
  49. what hooker headers will fit best
  50. those with fiberglass z-28 high rise spoilers...
  51. 305 TBI Power Upgrade
  52. Headlight Flicker?
  53. TBI High Idle (FYI)
  54. Are there any free mods for TPI?
  55. Ram Air TPI
  56. Plug wire install tips? Getting them on in tight spots?
  57. Low Restance Plug Wires???
  58. Holly Carb Questions
  59. 4-link in a 3rd gen?
  60. 12 bolt or 9 inch ??
  61. Fuel Gauge Acting Weird
  62. How do i get the spring off my TB
  63. flow #'s
  64. Front Disc Brakes
  65. 327 question.
  66. to the top
  67. Plans for next winter buildup
  68. Air Intake Snorkel On TPI
  69. help with first engine build
  70. my other car died and wont start
  71. Pulley Question... need help
  72. Modified 350TPI
  73. 1988 Iroc
  74. Just took out the smog pump... have a question
  75. Are these tires any good?
  76. SES points to MAF. Need help
  77. Help?????????????????????????/
  78. Coolant Temp Sensor Location
  79. 3.73 gears and sophn subframe connectors
  80. Posi Rear
  81. mods?
  82. Water temp gauge connection?
  83. Benifits of LT1 intake on L98?
  84. BF Goodrich g-force tires?
  85. Interior Upgrades
  86. Crystal Lens Headlights!! Need help Quick!!
  87. Tapping sound
  88. Single electic fan or Dual electric fans ???
  89. Fuel/ Engine light problem
  90. WTD: T56 Swap Info
  91. Idle Screw...
  92. How often should this be replaced?
  93. turbo fiberglass hood
  94. Question about 3rd gen weight.
  95. no power
  96. Thinking of buying a IROC-Z...need carfax
  97. Are Carbs Reliable?
  98. Service Engine Light... came on, went off
  99. Does anybody know the hp for a 305ci and or the 0-60?
  100. Sound System
  101. 3 inch Y-PIPE ???
  102. Radiator fans
  103. paging Rippin92rs
  104. in a jam with my ops as we speak
  105. 305 tpi fireing order
  106. Will this bodykit work?
  107. LT1 into a 3rd gen GTA
  108. roller rockers
  109. Assembly free 8mm wires?
  110. Where can i find an intake manifold for a 83 crossfire engine? should i go with carbs
  111. Car Sound Cat???
  112. N2O Kit
  113. heater smells
  114. OK I'm retarded...dumb Q about gen VI dfi
  115. New brake upgrade: LS1s for your 3rd gen
  116. Suggestions on a spark plug gap ???
  117. difference between iroc and rs
  118. Proportioning Valve: Drums to Discs
  119. Where can I get instructions on how to swap a thermostat?
  120. Fuel line from pump to carb questions
  121. 350 stalling, part 2
  122. High Idle??
  123. MSD ignition in TPI?
  124. Headers
  125. Rear Defrost not working
  126. Car runs like crap! pleeease help
  127. what is the difference between a 350 TPI and a LT1?
  128. which heads???
  129. Where to mount a tachometer ??
  130. Popping noise from drivers side front?
  131. Engine questions
  132. engine idles high on 2nd start-up after IAC adjustment
  133. Slp Loudmouth in 3rd gen
  134. Parking Light Bulb
  135. 89 iroc. posibility of 92 inst. cluster swap
  136. 3rd gen 5.7 vs LS1/LT1
  137. help w/ building a good TPI motor
  138. real 1le??????
  139. Name That Problem
  140. How Many Sensors?
  141. Question
  142. Whats the better hood? A Cowl Induction or a Ram Hood? Or is there something else?
  143. IAT sensor
  144. vette intake manifold on 86 tpi
  145. A few pics of the Formy
  146. engine swap for a 350 from a 2.8l v6
  147. Transmission Question?
  148. future of my iroc-z
  149. 1989 Idle problem
  150. Need your opinion
  151. Does anybody have info about a '83 crossfire engine?
  152. Some pics of my car
  153. Holley Carb probs please help!
  154. T-tops...what is the difference between latch and pin style??
  155. Any info about an '83 crossfire engine?
  156. Manifold Air Temprature relocating kit
  157. Floor mats - someone show me theirs?
  158. tpi intake manifold
  159. How much stronger are the 9 bolt rears?
  160. vortec heads and intake on 383
  161. code 33 and 36
  162. Carbed Z28, what will she run?
  163. Fuel Pump Question
  164. Speedometer acting whack
  165. Th200c To Th700r4
  166. Distributor Question
  167. post times...Steve10358
  168. question
  169. EGR. Whats it do?
  170. 110mph gage cluster
  171. Taking out the speed limiter
  172. Has the sun gotten to my paint?
  173. WOT=stall, what gives
  174. Need to find a dyno
  175. Bolt-In SFC's?
  176. Dashboard Problem... WTF
  177. Crystal Lens Headlights
  178. reverse lights out?
  179. Carburator for '86 Z28?
  180. Need help from carbed guys
  181. want 275/40 R17 tires..
  182. Parking Brake Cables Part #?
  183. New best for vortec headed 350
  184. The choke does not want to kick off? Car wants to idle high? any ideas
  185. I can smell gas...
  186. how much can a t-5 handle?
  187. Fuel Delivery Problem (Pressure Loss WOT)
  188. AC fan motor stopped
  189. who wants to play name that sound
  190. Too cold a spark plug?
  191. TPS voltage
  192. Open Element Questions
  193. Took the Feeble 305 to the Dyno today! 262.2 RWHP
  194. Good intake for 87 Z28 w/ LG4
  195. TPI to Carb swap?
  196. Which Ignition Coil Should I Get?
  197. my pictures and times for all 3rd gen message board
  198. What happens if I don't plug the header where the air pump vavle is suppose to be?
  199. Fuel pump?
  200. oil pressure
  201. 4th gen rear in a 3rd gen?
  202. Induction
  203. Track Times with L31 350 project
  204. to stroke or not to stroke
  205. tuned port
  206. Should i use unleaded gas or super unleaded gas for my 83 berlinetta v8?
  207. Dying up top
  208. Fog Lights??
  209. 4 Quarts of Oil in a 350 ??
  210. Header clearance from steering........
  211. why were early third gens so much weaker then later third gens?
  212. Guys with holley 4barrels + 305
  213. LT1 Swaped!
  214. Good exhaust system?
  215. Stalling story...part II
  216. Code 43 Question
  217. 700r4 Transmission
  218. Aftermarket lower intake?
  219. dimmer switch
  220. TPI stumble at WOT
  221. Converting to Fuel Injection
  222. Is there a way to take the free play out of the steering wheel?
  223. interior
  224. 2.73's to 3.73's
  225. HP/TQ Gain with L98 Vette Heads?
  226. dual snorkel/ open element question
  227. Hlloey Stealth Ram Questions
  228. 305TPI Heads Vs. 350TPI Heads Vs. Vette 350TPI Heads???
  229. Signs Of Fuel Pump Goin Out?
  230. numbers on intake ?
  231. no check engine light
  232. M.A.S. color coded wire diagram
  233. Is it possible to change my 4-speed automatic to a 6-speed automatic
  234. Shifter Knob Clip
  235. Need your help chosing exhaust bros!
  236. Exhaust manifold needed for 305 Tbi
  237. oil???
  238. Where Can I Buy a Y- PIPE ????
  239. Autoxray??????
  240. Score
  241. Top engine cleaner directions
  242. Fogging windows
  243. To much for a 2 bolt?
  244. Changing Alternator Pulley
  245. balance a 383?
  246. LTI block vs L98 block
  247. Good websites to buy 350 TPI Parts?
  248. heading to englishtown for fbody meet
  249. Spark plug example with 3000 miles
  250. TPI Heads???
