- What kind of intake
- 52mm throttle body
- Check for T56 in the mail
- we got air and maybe spark
- 305 to 383 swap
- Nice B4C, 3600 miles!
- is it true
- Car wants to lag before the power
- Code 33
- selling car
- LCA promlem
- Temp sensor ???
- 4-cyl. Camaro
- 10 bolt discs
- 9 bolt swap with lt1 brakes, what e-brake cables
- Lca
- Rear-End Question
- Please tell me who makes tubular kmembers!
- Gonna take her out to the track
- Fuel pump change is a PITA
- Can I use the stock chip ......
- Problem with new ignition wires?
- Decisions
- any LT1 swappers??
- need a rear for a 1990 camaro 3.73 posi in NJ
- 3.08 gear
- New factory carpet and back panels
- Alternative to SGI-5
- Is the swap worth it
- what size carb
- what should I do to beef up a 700R4
- 180 degree headers
- Is there anything i should do before or after putting a 383
- trunk pull down
- running like crap after header /y-pipe install
- 700r4
- What Blower for a 89 IROC
- Charcoal Canister hoses...
- What are the best traction boltons for an 83 Z28??
- Broken center console lid
- camber question...
- Ignition
- Top speed
- 92, TBI, Questions...
- Open element air cleaner Q's
- who has 91-92 145 mph speedometers???
- 1990 Iroc-z
- Distributor cap and rotor ??? 89 IROC
- Best way to separate Tire/Wheel
- Front sway bar?
- 350 Questions
- Hey, PRO BUILT!!!! What happened to your web page??
- hatch mortor
- 1st gear Rev HELP!!!
- Wheel bearing
- Over heating issues, I think I need a new fan.
- Head and Cam Combo???
- headlight motors
- L98 Aluminum headsvs Vortec Cast Iron heads
- My LT1 got totaled last night, now I have a T56. Help!
- What do I need : T56?
- 700r4 .500 boost valve
- Rim Size
- 3rd gen video
- 700r4 13 vane pump upgrade
- crossmember
- How do I install Roller lifters?
- Will Edelbrock performer intake work with Vortec Heads?
- fuel pump not priming for hot starts.....
- What does Liters mean?
- torque converter stall speed
- Help With A 1990 Camaro 350 TPI
- Iroc-z Stickers
- MAF burnoff
- LT4 HotCam
- Help With A 350 Camaro Tpi
- Engine Swap Questions
- Got a T-56, question about flywheel
- A/C vent problem
- anyone have hedman long tubes?
- est. COST for 6sp conv. Vs th350
- New Holley Stealthram Benefits/Questions
- Purchasing an 86 Z28
- Help with strong exhaust odor
- Factory Rev limit? Lets talk about it..
- Aerodynamics of a 3rd gen
- opening up hood louvers...
- What does blueprinted mean with built engines?
- 1990 camaro 350 tpi
- 3rd gen rear chunk help!
- 1990 Camaro TPI 305 350 help! please : )
- MPG On an 86 IROC?
- SuperRam vs. LT1 Intake (finally)
- good or bad choice
- simple egr question
- 86' Iroc-z
- Idle trouble!
- axle movement
- Need your opinion for new engine
- foggy parking lights
- 350 vs 305
- Differences in 91 and 92
- Sohn.net
- 1.6 Ratio Rockers
- Anybody tried summit headers?
- Symptoms of cracked block.
- intermittent misfire... tach needle jumps
- A/C question. blowing the fan fuse
- Another rear end question...
- MAP sensor?????
- who wants to help me pick a wheel?
- need to know rims sizes!?!?!?!?
- Clunka-Chunka Tranny Again!!
- Should I buy??
- redline fluids??
- Starter
- LS1/T56 In a third gen?
- injector swap.
- hit a curb going 40mph
- need some help figuring out what this clunking sound is
- Sd Vs Maf
- Synthetic trans fluid
- Help, car not putting out spark like it should.
- Headman headers
- DropZone Or Eibach Springs????
- Motor and a few other questions
- might be getting rid of the 3rd gen for a 4th
- Question on Torque Converter
- cam z28 question (noobish?)
- I need manual fan control?
- Rear end question
- fog light question
- ram air install need help
- tremec tko 2 vs richmond 6 speed
- Those who have the Cable-X from Abbott...
- A/C not moving any air
- Replacing 700R4 with a 350, any problems???
- hood louvers
- Question
- What do u guys think of my 92's New paint?
- some ring and pinion questions
- electric fuel pump shuts off to hooley 4bbl carb
- Need Some Feedback.
- What the Heck!
- Headers/emissions
- gutting the mas
- Competition Engineering Bolt-on Sub-Frame
- Need Help On Some Performance Mods...
- Waterbury Connecticut???
- LT1 rear brakes same as L98 rear brakes? (non 1LE)
- Cam?Nice smog legal one out there?
- Swapping from MAF to Speed Density. Input???
- true dual 3"
- TPI Chip Burning
- stall
- rebuilt 700r4 value
- White smoke during start up
- Car Lurches When Shifted P to D
- Wanna blow a very little bit of cash on something fun and useless
- Tranny Crossmember?
- Long Tube Hedders...
- degreeing a cam
- wanna get more power for my 89
- Rattling Stick!
- If I build this stuff, will people buy it?
- Might be getting a LT1 from a 95 Caprice....
- Lifters?? 80-85 block
- 92 RS Questions...
- help help!! broken new head!!
- headliner sagging
- 5 speed and 6 speed flywheels
- engine seems to be revving too high!
- Fuel leak?
- Please Help!
- Quick, easy question..........
- Exhaust question
- tire size?
- Some pics of my car
- need to help pay for funeral so i have to sell my dream
- Need a MAF sensor.
- does full roller rockers make more noise than stock?
- Chatroom dont work
- I know the answer but need explaination
- Block casting Numbers
- 7 vane or 10 vane pump??
- Stock 305 with boost 1/4 times ???
- 700R4 Rebuild Questions....
- 84 Z28 HO Transmission
- Keep blowing ACC FUSE?
- 305 Swap ?'s ...
- 8.8 mm wires
- 383
- Limited Slip died???
- Lifter dia. of a 89' SBC??
- 3 inch exhausr. Mistake? Help please.
- Help! Computer Controlled Quadrajet Questions
- Eibach pro kit springs. Anyone want a set?
- radiator fans acting gay
- long tubes and a starter
- Buy My Car!
- Speedo not working after gauge cluster swap..
- does a 1991 305 TBI have the same flexplate as a 1990 350 TPI
- Charging AC
- idle
- Mufflex Exhaust with a Spintech muffler
- Tokico Shocks/Struts
- Do i really need SFC?
- Can my stock diff can keep up with my new engine???
- What SBC's came with PM rods?
- 1988 Iroc-Z
- HOW do i get the center caps off of my RS rims??
- what tranny do I have?
- Very loose auto shifter.
- where's the power?
- Cam Selection
- Vibration after tranny mount install!
- battery tray
- f/s firebird hood 82-92 ram air ws-6 cheap
- ZZ4 and LT4 questions
- running weird??
- Tips on looking for short circut???
- Header Choices?
- My friend is looking at an 85 IROC need opinions on what it is worth
- Rare GTA Digital Dash
- terrified
- Installing guages, have questions!!
- Best performance radiator
- Best Sub frame connectors
- TPI Vs. Carburator?
- TB Bypass??
- open/closed loop/limp home help
- Need to replace rear seal. Gotta ?
- Keeping her cool???
- 90 iroc computer trouble or not.
- LT-1 in a 86 I-Roc
- No real choice when it comes to lowering springs
- She has air; all systems go
- Driveshaft Problem
- ? kind of power out of tpi
- 1982 z28
- 700R4 manual valve body or shift kit?
- Help Please!
- I hate powdercoated wheels
- 26 spline or 28 spline
- Coil-over struts
- 91 Z28 window lift motor replacement
- backspacing
- Corvette heads?
- Paging DarthIROC
- Ignition Upgrade....
