Gauges?
Old Jun 9, 2006 | 08:08 AM
mook99TA's Avatar
Gauges?
I am looking at a water temp gauge and Trans temp gauge. Which will be better to use, Mechanical or electric? on an LS1
Old Jun 9, 2006 | 07:53 PM
mook99TA's Avatar
Re: Gauges?
anyone?
Old Jun 9, 2006 | 08:02 PM
69z-28's Avatar
Re: Gauges?
idk about trans temp, ive never used one, but i can tell you for sure get an electric water temp gauge, otherwise you will be running copper line through your interior and crap. i would say electric for the trans too, but like i said, im not sure.
Old Jun 10, 2006 | 07:34 AM
AL SS590 M6's Avatar
Moderator
Re: Gauges?
I went electric for both
Old Jun 10, 2006 | 09:00 AM
mook99TA's Avatar
Re: Gauges?
did you use the place for your factory sensor for the water temp
Old Jun 12, 2006 | 06:50 AM
Moderator
Re: Gauges?
I haven't installed them yet but you have to leave the factory sensor as it's the one that the PCM uses for calibrating the tune.
I'm going to us the passenger side head for mine.
Old Jun 14, 2006 | 05:10 PM
bshay25's Avatar
Re: Gauges?
electric is twice as easy if you can afford them because they are a lot more expensive
Old Jun 14, 2006 | 06:15 PM
mook99TA's Avatar
Re: Gauges?
Not exactly electric are cheaper and a little more work to put in.
Old Jun 15, 2006 | 05:46 AM
Moderator
Re: Gauges?
I take it you've never priced fuel pressure guages?? Manual $40 electric $200.
Old Jun 15, 2006 | 07:28 PM
mook99TA's Avatar
Re: Gauges?
Have you ever priced water temp or trans temp?
Old Jun 15, 2006 | 10:51 PM
94CamaroZ28's Avatar
Re: Gauges?
Fuel pressure gauge has a REALLY freaking expensive isolator to guarantee no high pressure fuel leaks under hood. And if you put a mechanical fuel pressure gauge in the passenger compartment of your car, I'll pass on a ride. Often electric gauges are a bit more expensive, but you have to compare apples to apples. I'd rather run wire than hard lines through my engine bay.
Old Jun 16, 2006 | 07:35 AM
Moderator
Re: Gauges?
Yep I have them in a box behind me. One day I'll put them in the car
Old Jun 16, 2006 | 04:41 PM
mook99TA's Avatar
Re: Gauges?
exactly I personally don't like fuel in my passenger compartment!
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
