What's the weakest link to turn 6500?
Old May 29, 2006 | 12:53 AM
Black Cloud's Avatar
I've been told rod bolts,head bolts,timing chain,etc.I can't buy them all at once.I have a 6.0L truck engine with new valvetrain and I'm gonna shoot 200 no2.
What do you think?
John
Old May 29, 2006 | 01:10 AM
Sparkz28ss's Avatar
Re: What's the weakest link to turn 6500?
pushrods and springs
Old May 29, 2006 | 01:28 AM
Already did all that.I'm thinking bottom end.This is a carb,MSD Timing,pg,5000 stall setup.
Old May 29, 2006 | 07:16 AM
Demon SS's Avatar
actually the stock components will handle 6500rpm, many folks are pushing a little more than that, but it is living dangerously.
I would change the rod bolts and the timing chain.
Old May 29, 2006 | 08:06 AM
PhantomTA's Avatar
Moderator
Rod bolts, then timing chain.. like said above
Old May 29, 2006 | 12:48 PM
Rod bolts seems to be #1 even though the owner of ARP told me Fri. he had never heard that.He said mains and head bolts.
Old May 29, 2006 | 01:44 PM
Demon SS's Avatar
I have personally never seen the mains or stock head bolts be an issue when spooling past 6500rpm.
I have however seen the stock rod bolts let go and the carnage caused when that happens.
Old May 29, 2006 | 02:09 PM
RussStang's Avatar
6500rpm should be fine for the stock rod bolts, but you may want to change them anyway. 7000rpm often is pushing it (especially for the pre 01 engines), and an accidental overrev could spell disaster.
Timing chain couldn't hurt either.
Which ones do you suggest?
Old May 29, 2006 | 05:29 PM
Greed4Speed's Avatar
Get an LS2 chain for $40 if you're going to change it. There I saved you some cash.
Old May 29, 2006 | 08:18 PM
RussStang's Avatar
This is a pretty good idea. The LS2 chains are setup to take 6500rpm over and over again from the factory, and they don't cost very much.
Old May 29, 2006 | 11:13 PM
TY,TY Very Much.What car would this be off of?Or part # ?
Thanks,John
Old May 30, 2006 | 09:44 AM
Just call or visit the website of a sponsor like Texas speed or the Ws6 store and its listed as an Ls2 timing chain. No need to change sprockets either.
DirtyDaveW
Dec 1, 2016 05:37 PM
meissen
Jun 1, 2015 07:59 AM
DrMilhouse
Aug 6, 2002 08:45 PM
formula79
26
Aug 5, 2002 12:21 PM
sc93
Jul 26, 2002 02:02 PM
