T/A has a bad dead spot need help
Old May 22, 2006 | 08:48 PM
99M6T/A's Avatar
When I drive my car it has a dead spot it will quit pulling for a split second then it comes back on.
Took it to the dealer and told them it was the cats to get it scanned for free because the cats are still under warranty.
They called and said the cats were fine and that the problem was that the car had a bad air/fuel mixture they didn't tell us lean or rich.
What can cause a bad a/f mixture also can it something else causing it.
PS-- The car has fresh plugs and wires so I doubt thats it. (we thought this would solve the problem guess not so I'm back to square one
Old May 22, 2006 | 09:16 PM
LT1Formulation's Avatar
Re: T/A has a bad dead spot need help
If your car has a K&N air filter, try cleaning your MAF. I have had so many times where drivability issues led to that damn thing being coated with K&N oil.
Old May 22, 2006 | 10:48 PM
SSpdDmon's Avatar
Ditto on cleaning the MAF. Also, might as well pick up a new fuel filter while you're at Autozone picking up the "QD Electronic Cleaner."
Old May 25, 2006 | 09:06 AM
6spdpewterZ's Avatar
I second the new fuel filter!
Old May 25, 2006 | 12:42 PM
Sparkz28ss's Avatar
bent push rod......
may Ls1 would flat spot at 4500-6500 rpms.... just a random no pull ...no more power....then...the next run it would yank up to 6500
turns out it was a bent push rod......and it never made a ticking sound..
Old May 25, 2006 | 07:00 PM
GhostZ28's Avatar
DUDE i had the SAME question! I bought a new lid/air filter and cleaned my MAF all at the same time and my dead spot vanished! I dont know which fixed it, but try either. I'l almost 100% sure that what you're experiencing is the same thing i was.
Victor Lamb
Aug 26, 2017 02:52 PM
shroyvin56
Apr 19, 2015 09:40 PM
Fatdog2
Feb 13, 2015 08:19 PM
mattszm6
Dec 14, 2014 07:09 AM
