shorty headers install
Old Jun 21, 2006 | 10:30 PM
skifast87's Avatar
So i was under the hood of the car today (02 z28 6speed not sure if it matters for my question or not) but what does it take to put shorty headers in. It seems to me i would have to jack the motor up or use my engine lift. or can it be done with out moving the motor at all.
Old Jun 22, 2006 | 06:29 AM
teke184's Avatar
Re: shorty headers install
install should basically be the same as a LT install. but probably wouldn't have to jack the car quite so high.
shouldn't have to move the engine around at all, everything pretty much slips into place.
check out my LT install guide, it covers pretty mcuh everything.
any other questions...just ask.
and it's a good idea to swap your motor mounts for some good poly ones while you have everything out. it's simple with the manifolds removed, and a serious PITA after everything is back in.
Old Jun 22, 2006 | 06:48 AM
StudyTime's Avatar
Keep in mind you won't see any real world gains from shorty headers over your 02 manifolds.
Ben T.
Old Jun 22, 2006 | 09:04 AM
teke184's Avatar
yeah...maybe 5hp if you stick with the stock ypipe and cats....maybe 10 if you go offroad pipe and bigger Ypipe.
it's really not worth the trouble
Old Jun 22, 2006 | 01:59 PM
skifast87's Avatar
Well im trying to keep cats. Unless i can get a Y pipe where they bolt in and out with a set of test pipes. Can i do long tubes with cats? and would i get a better gain.
Old Jun 22, 2006 | 04:10 PM
teke184's Avatar
longtubes with cats will blow any set of shorties out of the water. a solid 15-20 hp depending on other mods.
and yes you can put cats on LTs...just shop around...although they are not cheap.
Old Jun 23, 2006 | 11:00 AM
skifast87's Avatar
sweeet then this is what i must do. Thanks for the help
Old Jun 23, 2006 | 05:06 PM
SSpdDmon's Avatar
Although, moving the cats is not technically legal. If you wanted to do shorties, all you need are rhino ramps and an extra set of hands when it comes time to get the first bolt started on each side.
Old Jun 23, 2006 | 08:14 PM
skifast87's Avatar
i think form the stand point of power gains. i am just gonna do the LT's but if i do happen to do that it is a good idea i will keep it in mind.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
