Removing PS Pully
Old Jun 7, 2006 | 09:50 AM
Wildwill2855's Avatar
Removing PS Pully
We tried and tried and infact used 2 diffent removers. One was specificly for removing the power streering pully / something else. The other we used was a 3 claw pully. Neither worked? Cant get that damn thing off the head? How do we do it, i mean we had the 3 claw chip the back side of the pully we had it so tight, the other that was just a screw with a nut setup that would just make poping sounds when it would get tight. We sprayed it down overnight with wd40 no luck. I think this is some BS engineering by gm, some of the stuff i see anymore is obvouisly intentional in the way that they dont want the common person to work on their cars anymore. I mean on lt1/4's weve got the pully with the 3 holes in it where you just rotate to get to the bolts, why the change? Thanks for the help.
Old Jun 8, 2006 | 07:12 AM
AL SS590 M6's Avatar
Moderator
Re: Removing PS Pully
Don't need to take the pulley off. Work the mounting bolts out a little at a time evenly with an open ended wrench. Takes a little time and patience but it's not hard.
Go to www.ls1howto.com and print out the heads/cam removal/installation instructions. It outlines everything that you need to do and all of the little tricks to do it easier.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
