Best spark plugs for F14 cam
Old May 9, 2006 | 04:07 PM
deadmeat2004's Avatar
Should i use a cooler plug with the new cam or not??
Old May 9, 2006 | 04:16 PM
teke184's Avatar
Re: Best spark plugs for F14 cam
as far as i know there is no reason to...
standard plugs gapped to .060" is all you need...or just leave them at .050" like they come.
Old May 9, 2006 | 04:20 PM
PhantomTA's Avatar
Moderator
Depends...
LOL
Old May 9, 2006 | 04:24 PM
Originally Posted by PhantomTA
Depends...
LOL
go on....
Old May 9, 2006 | 09:03 PM
PhantomTA's Avatar
Moderator
Originally Posted by deadmeat2004
go on....
....on a few different things
Old May 9, 2006 | 09:17 PM
ok.. and the things would be
Old May 9, 2006 | 09:29 PM
PhantomTA's Avatar
Moderator
Dont buy into any +4 BS or anything like that. Stay with a Copper core.
If you have higher compression, or n20 or boost you may want to go a bit cooler on the heat range...
As far as brand..
Its a spark plug, if you spend 70$ on a set you qualify to be beaten with a sock full of quarters. My NGK TR5's that cost me less than 12$ seems to work just fine in my 10.5-1 compression 236 cam ls1.
Old May 9, 2006 | 11:46 PM
thanks, thats basically what i needed to know.
Old May 10, 2006 | 12:18 AM
Kraest's Avatar
Retired
OEM-style are fine.
Old May 10, 2006 | 09:14 AM
PhantomTA's Avatar
Moderator
Originally Posted by Kraest
OEM-style are fine.
Exactly
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
mritter1965
Feb 9, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
