white smoke from below hood
Old May 14, 2006 | 12:28 PM
bmotwani's Avatar
Guys, I wonder if anya u guys came across this but it's happened thrice for the last 5 days or so while driving. But by the time I pull over to open the hood smoke's subsided. It appears for a good 3 seconds at a time from passenger side hood somewhere north of the battery. Took it to the mechanic today he too is clueless. No burnt wires or harnesses visible. I am sure I saw it coming from right under the hood. Would anyone know what it could be? Thanks for any suggestions.
Old May 14, 2006 | 02:20 PM
wdtiger's Avatar
Re: white smoke from below hood
Coolant leak?
Old May 14, 2006 | 07:08 PM
GhostZ28's Avatar
ya i'm guessing a coolant line leak?
Old May 15, 2006 | 11:32 AM
bmotwani's Avatar
Thanks for it, you could be right as i last week put a brand new radiator and coolant and the engine now heats up unlike before to almost 112C when the max used to be 100C. Is there a co-relation? Looks like the shop guy hasnt done it proper.
Old May 15, 2006 | 12:42 PM
Iron_Duke's Avatar
Coolant has a very distinctive smell...do you not smell it? Especially when you are driving and come to a stop?
I've had issues with coolant leaks in the past, so now I'm like a bloodhound with the stuff...first whiff and I'm under the hood. (Although I've solved my issues for the time being) :luck:
Old May 15, 2006 | 01:15 PM
GhostZ28's Avatar
with it over-heating there is a very specific process in bleeding air out of the coolant line. The mechanic probably did it wrong. I'm guessing you living in Dubai, there arent alot of camaro's around so thats understandable. look up a good guide on the internet.
as for the leak, it doesnt take alon of coolant on a hot engine part to expell alot of white steam.
Henson071
Dec 30, 2015 09:55 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
alphaauto
Jul 26, 2015 04:40 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
