Tick tick sound how to resolve ...!
Old May 5, 2006 | 03:00 PM
roadkillZ28's Avatar
Its not piston slap for sure, the sound coming from the v/v train (driver side).
it 'd be either; bent pushrod / a bad rocker arm, however the engine running fine!
If so ... what should i do? replacing the defective parts only or replacing all valves, pushrods, springs...???
another q: if i leave it with no repair what will happen?
thanks in advance
Old May 5, 2006 | 03:48 PM
Greed4Speed's Avatar
Re: Tick tick sound how to resolve ...!
Most likely a pushrod. I had one do that and it wasn't bent, just in a bind.
Just pulling it out and slapping it back together fixed it.
Old May 5, 2006 | 06:12 PM
smallblock458's Avatar
My 02 SS has the same noise! It's at camshaft speed and sound's like from bank 1 V/C. Let me know when you figure it out!!!!!
Old May 6, 2006 | 08:46 AM
AL SS590 M6's Avatar
Moderator
You can change bad pushrods or lifters on a one for one basis with no ill effects.
Valve springs should only be changed as sets.
Old May 6, 2006 | 02:02 PM
Thanks alot guys,
so in this case i think i'm going for stiffer rate springs what do u think?
Old May 6, 2006 | 02:06 PM
Thank guys,
in this case i think i'm giong for stiffer rate springs, what do u think?
Old May 6, 2006 | 10:29 PM
blue's Avatar
I would check all the exhaust manifold / header bolts to be sure they're tight and look for any holes in the exhaust gasket before taking the valve covers off and readjusting rockers. An exhaust leak will make a ticking sound.
FredM
Exhaust System
Feb 8, 2016 02:10 PM
cmsmith
Sep 14, 2015 09:25 PM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
GT what?
Jul 14, 2015 10:17 PM
Noct
Jul 14, 2015 01:18 AM
