4.10 on A4 SS?
Old May 17, 2006 | 10:14 PM
CrazySS35's Avatar
Question 4.10 on A4 SS?
ok so its a done deal..im installing the hooker supercomp headers and y pipe on my 02 SS by the end of next week..hopefully sooner...now i have the idea of putting a 4.10 in there...good idea? lots of adivse wanted! thanks
Old May 17, 2006 | 10:51 PM
Knowklew's Avatar
Re: 4.10 on A4 SS?
4.10's are kinda steep for a 4L60E you might wanna go with 3.73
Old May 17, 2006 | 10:53 PM
Kraest's Avatar
Retired
Re: 4.10 on A4 SS?
My 3.73s turns 2500 rpm on the interstate at 70 mph. Not sure how often you drive your car on the interstate, but I wouldn't go any bigger than a 3.73.
Mike
Old May 17, 2006 | 11:26 PM
CrazySS35's Avatar
Re: 4.10 on A4 SS?
What would be entirely wrong with a 4.10
Old May 18, 2006 | 04:22 AM
wdtiger's Avatar
Re: 4.10 on A4 SS?
With 4.10s, you'd be a little over 2600rpm at 70mph in 4th. For drag racing, it would mean you might end up shifting into 4th before you cross the line. Probably not if you're stock though... redline would come up at 112mph in 3rd. The 3.73s will carry you to 123mph in 3rd. The 4l60e isn't known for handling a wot 3-4 gear change very well so it might be best to avoid that at the strip.
Old May 18, 2006 | 08:11 AM
S8ER95Z's Avatar
Re: 4.10 on A4 SS?
I second the 3.73s and avoiding the 4.10s
Old May 18, 2006 | 09:32 AM
Greed4Speed's Avatar
Re: 4.10 on A4 SS?
4.10s are also weaker.
Old May 18, 2006 | 01:54 PM
S. Holley's Avatar
Re: 4.10 on A4 SS?
I have 4.10 in my SS CAMARO....
but I have a T56
Old May 19, 2006 | 10:04 AM
Capn Pete's Avatar
Re: 4.10 on A4 SS?
Buncha pu$$ies!! Go with the 4.10's .
I've had/have 3.73's and 4.10's with my A4. Going from 2.73 to 3.73 was a big jump, but from 3.73 to 4.10 isn't that much worse on the highway, and for 1/4 mile running, they're awesome. If you start running real fast at the track, you've got the option of going with bigger tires, and/or higher rev limit (beefed up valvetrain required) to compensate for the top speed of 3rd gear.
I suppose if you were gonna run nitrous or something though, you may want to hold back at the 3.73 mark?
Old May 19, 2006 | 11:59 AM
SSpdDmon's Avatar
Re: 4.10 on A4 SS?
Another vote for 3.73's....and one reason the 3>4 shift is known for being hard on our trans is because there's no torqure reduction in the factory tune for the 3>4 like there is for the 1>2 and 2>3. Just before the trans shifts, the pcm pulls a huge chunk of timing for a split second so engine power is reduced. This gives the trans a fraction of a second to get into the next gear without the effects of a "power shift." Many tuners reduce or remove torque management when tuning A4's. But, I've always thought to keep at least half of the factory settings and even added torque management to my 3>4 shift just to be safe.
Old May 21, 2006 | 12:27 AM
CrazySS35's Avatar
Re: 4.10 on A4 SS?
yea well i hear from friends that at a cruising speed on the highway...i could be running at 4000 rpm...thats actually really high and it seems like it would do harm to the car in some way..or would it?...im still not convinced between the 3.73 and the 4.10 but im leaning more towards the 3.73
Old May 21, 2006 | 02:44 AM
wdtiger's Avatar
Re: 4.10 on A4 SS?
Did you not read what i wrote?
Run the numbers yourself. http://www.f-body.org/gears/
Old May 22, 2006 | 11:42 AM
Capn Pete's Avatar
Re: 4.10 on A4 SS?
To cruise around ~70 mph is about ~2600 RPM. ~80 mph is about ~3000 RPM . That's with 4.10's. 3.73's are slightly lower RPM's on the highway.
I'd like the proof how 4.10's are weaker than 3.73's though . I've heard this time and time again, but I don't know the reasoning or justification?? The ring gear is pretty much the same 41 tooth gear as 2.73's, 3.42's, and 3.73's have! The only thing different is the pinion has 10 teeth instead of 11, 12, or 15.
Old May 22, 2006 | 06:22 PM
Plague's Avatar
Re: 4.10 on A4 SS?
How loud do you want the car to be when cruising down the highway? 2500 rpm's is pretty loud for crusing. I dont know if you care about it, but I thought I would bring it up.
Old May 22, 2006 | 11:14 PM
LS1Kid717's Avatar
Re: 4.10 on A4 SS?
hey mike lol
