P&P throttle body
Old Apr 22, 2006 | 08:24 AM
GhostZ28's Avatar
P&P throttle body
I saw a guy's TB that had the indentations filled with an epoxy of some sort to smooth out the airflow. Does anyone know what I'm talking about, or what to fill up? and if so, do you have any pictures or know what type of epoxy to use? I'd think something like JB weld, but I dont want anything breakng off and making its way into my intake!!! I was planning on pulling off my TB and doing a PP job in the next couple weeks, but I saw this a couple days ago. thanks for the help
Old Apr 22, 2006 | 08:36 AM
AL SS590 M6's Avatar
Moderator
Re: P&P throttle body
We just had to undo mine (ground all of the fill back out). The filling of the IAC passage didn't allow enough air in to let the IAC work properly with the bigger cam that I have so the car wouldn't idle even with a good tune. Took the fill out and now it idles fine. And according to the dyno it didn't hurt my power any.
Old Apr 24, 2006 | 12:07 AM
GhostZ28's Avatar
I just got finished porting, and am almost done with the polish part. i need to be able to drive it, so i put it back on, and I'll finish the polishing job in the next few days. i've noticed a difference, moderately better, not GREAT, but i'm happy.
I also noticed that my throttle cable is pretty loose, and its imparing my WOT by about a couple millimeters, i cant see any adjustment on it, how do i tighten it?
Old Apr 25, 2006 | 12:16 AM
GhostZ28's Avatar
WOW so i took my final steps in porting and polishing, i'll link some pics in the morning
2 problems: My idle is now at about 900-1000rpms..... and i spilled coolant on my belts, now its screeching lke a b*tch.. lol
After i got back from my test drive (AWESOME throttle response now) i let it idle out of gear and clutch out for a minute, and it went back down to 500rpm. i turned it off and called it a night..
When i was reinstalling the TB blade, i checked to see if i had a large amount of light creeping around the circle when i had the blade fully closed, so i know i didnt OVER port, i havent adjusted my idle screw yet at all.
Does the car just need to be driven for a few miles to correct itsself, or should i start screwing with my screw?
Old Apr 25, 2006 | 08:27 AM
teke184's Avatar
the idle screw is the WRONG way to adjust idle on these cars...don't mess with it.
to adjust the "slack" in the cable, follow it upstream and you'll come to a connector looking thing...maybe 18" from the tb. it is the adjustment connector.
i found out my TB was only opening about 80% due to too much slack in the cable. adjusted that and it works fine now.
Old Apr 25, 2006 | 01:13 PM
GhostZ28's Avatar
thank you, I'll get to adjusting soon. And after driving for about 20 min today, my idle is fine now.
To anyone who reads this, if you ever have the time, P&P your throttle body if you dont want to shell out the cash for a new one or pay to have it done! the gain is WELL worth it. it really woke my engine up alot more than I expected.
Old Apr 27, 2006 | 10:38 PM
GhostZ28's Avatar
My idle is still weird. when it starts up it idles 800-1k rpm, then after 15 min or so of driving it calms down to 500.... fix?
Old Apr 28, 2006 | 06:33 AM
teke184's Avatar
buy a new throttle body....sounds like you may have screwed something up.
Old Apr 28, 2006 | 10:33 AM
SSpdDmon's Avatar
Assuming there's not any air slipping around the blade and you didn't obstruct the IAC hole in the top of the TB, it's an easy fix. If you know someone with some scanning software (EFILive, HPTuners, etc.), have them log your idle characteristics. You can adjust your idle with the set screw (get IAC counts to ~70 at warm idle) and it is ONE of the RIGHT ways to do it.
FYI - Your car has an Idle Air Control (IAC) valve that adjusts airflow (adds/subtracts a little) to control your idle rpms. It also has an idle adder for startup conditions that lasts about 20 seconds before the revs start to come down at a rate of 5rpm/sec. That would probably explain the first few minutes of high idle. The car can also learn over a period of time how much trim needs to be added/subtracted with the IAC valve to maintain the right rpms at different coolant temps. That would explain why it "learns" itself back to ~550rpm after a few minutes. Let me know if you have any questions about fixing this and I'll walk you through what needs to be done...
Old Apr 28, 2006 | 08:55 PM
GhostZ28's Avatar
I think you nailed it down pretty good for me. I was just wanting to know if it was normal. Yeah, i hear it isnt exactly good to fill in the iac and drill a couple holes, so i left em open and just ported the lips. thanks for the info!
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
