Doing 3.73 Gears, what to expect from stock 10 Bolt?
Old Jun 13, 2008 | 12:16 AM
neil350's Avatar
Assuming its an all original 72K mile 10 Bolt, what should be expected to be replaced? I have the gears, a mini install kit (crush sleeve, shims, ring bolts, gasket, pinion seal) as well as a new 10 Bolt Cover from TA and TA Stud kit. I was told by the gear installer that the car may need new carrier bearings, what else should I expect?
Old Jun 13, 2008 | 09:09 AM
1redTA's Avatar
re
sounds good, I replaced the bearings on the end of the axles also. Just make sure the installer has enough shims to set everything up right and have a manual for all the specs o how tight the crush sleeve will be, backlash,blah blah blah. Is he using a pinion depth toll or is he going to be using the marking compound t set up your pattern? Good Luck, mine howls from the street twin
Old Jun 13, 2008 | 09:41 AM
SNOTGREEN's Avatar
That is good info, and very good advice.
Lol, my stock rear howls from racing/driving w/drag radials for 10 months.
Old Jun 13, 2008 | 01:41 PM
LearJet's Avatar
Mine whines like a schoolgirl cuz I drank to much beer while I was putting them in!*
Old Jun 13, 2008 | 04:28 PM
neil350's Avatar
I'm taking it to a performance shop that specializes in F-body stuff, hes done quite a few gear installs so I'mhoping between the kit and shop, they should have all needed components and tools. The kit has a marker in it.The bearings on the axle ends, wouldnt happen to be the wheel bearings would they? I'm thinking I should tell them to replace those as well just for maintance and ease at that point, at one $10 a pop, may as well. Also what about the pinion bearing?
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
