Will a t5 5sp v6 transmission fit v8
As stated will a 5 speed transmission out of a 95 v6 camaro fit an lt1? Ita a question someone asked me on one of my ebay auctions and i figured one of you guys could answer this. Thanks.
I would have figured it was the same transmission?
The bolt pattern is the same on the back of the LT1 as it was on the older 5.0L, and I thought the V6's used the same transmission (and I assumed they had the same bolt pattern too?
) ...... but I could be wrong?!
It wouldn't surprise me that the clutch setup may be slightly different though
the v6 trans in thirdgens had a different bolt pattern than the v8's at leas the earlier ones did ( I have one of each sitting here) the bell housings are different. I am not sure if a v8 bellhouseing will bolt to a v6 trans though. I have not taken them apart yet to try. However, the power output of an LT1 will destroy that trans. they never put a t-5 in anything over a 305 in a thirdgen for a reason. The t-s in the ford products are not exactly the same. there are a few differences if i remember correctly which made the ford ones a little bit stronger.
Ok, so the difference is the bell-housing. That makes sense. Otherwise, they're essentially the same main unit?
It would stand to reason that none of that changed from the 3rd- to the 4th-gen cars?!
Apr 3, 2015 10:54 AM
Sarahrope64
Nov 27, 2014 11:17 AM
