lost 3rd and 4th. Very upkept 4l60E. Suggestions?
Hi.
I have a 95 4l60E in my 94 z28. I have done the pwm mod. My transmission is very up kept. I just recently just changed the filter and all of the fluid once again about 3-4 weeks ago. Used the same fluid as b4. (maxlife ) (Tranny cooler has been installed when it was on the 95, and one is on the 94 too) I live on a VERY bad, bumpy dirt road.
Yesterday when i got off the dirt road, driving normally, i looked down to see how fast I was going and I noticed the RPMs were way too high. I immediately slowed down and moved the shifter around. I have manually 1st and 2nd. but no 3rd or 4th. I checked the fluid level. (wasn’t low at all), added 1/2 QT just incase and tried again. Same thing. Its like it want to engage but for some reason cant. Drove it home in 2nd.
Would this be a solenoid prob.? Valve body prob. Or even the VSS?? IM HOPING that it is NOT the 3-4 clutches! (its even a performance upgraded/rebuilt tranny) w/ higher stall TC.
Could I get some input on this, because If i need a new tranny....my car will be off the road for a good year or so...
I have a toasted 94 4l60e laying outside (one of the planets exploded). and the electronic parts could be cleaned and installed for testing, and replaced with bran new if issue fixed.
Thank you all!
Thank you all!
Hmm, what does the fluid look/smell like?
When you added the half quart was it full to begin with? Theres no such thing as a little low on fluid with a 4l60e.
I dont really think its a shift solenoid or anything like that, it would probably throw a code and just default to 3rd gear.
Although, I guess you could just be stuck in second gear. Did it feel like the car was pulling when it was supposed to be in third or fourth? Just with the rpms pretty high? I suppose you could have a shift solenoid stuck in that case, perhaps a checkball is hammered into the seperator plate and not allowing proper operation.
Fluid doesnt smell burnt at all.
Thank you all
I would think it unlikely to be a check ball . I am afraid there is a 3-4 clutch issue , possibly broke out the snap ring in the input drum. The rev high and move is actually first. In the absence of the 3-4 clutch the shift literally becomes 1-2-1
I will make a Datamaster log within the next 2 days, Performabuilt, so when i do could you please look at it and maybe tell me a little more, and prolly have more evidence its the 3-4 clutches
http://www.fileshack.us/get_file.php...ne++2+town.uni
Please look into it n see maybe could be something else?
When I put it into 3rd, it "feels" like it grabs, and the rpms are a little higher then in nutral.
Later in the file i was driving at highway speeds, i would speed up in 2nd, and just coast in N.
Thanks everyone!
carguyshu
01-22-2017 11:19 AM
alex5366
06-14-2015 10:31 PM
Boss002
05-20-2015 12:55 PM
mspennyhughes
11-28-2014 03:22 PM
