broke 1 bolt on flywheel-I can still run it right?
Old Jun 10, 2008 | 09:51 AM
CamaroCasanova's Avatar
This is on a 01 3.8 5 speed. Stupid bolts on this car-some appear to be metric, some not...Case in point, oil pan bolts are 3/8 NOT 10mm and the flywheel bolts are 9/16 instead of 14mm. Well, my dumba$$ tried to use a 14 mm socket assuming all bolts on "modern" cars are metric, and got a socket stuck on one of the bolts. I was using an impact, and I tightened it up and kept tightening it hoping it would jar loose from the bolt. Nope. Broke it. So it appears to me with the amount of bolts on the back of this thing (8) that 7 should work. What do you think? Changing a clutch should not involve this much thought.
Old Jun 10, 2008 | 04:45 PM
I would not run anything on the flywheel or clutch without all the proper bolts.
Old Jun 10, 2008 | 10:24 PM
Bolt came right out luckily...Found a similar one in my parts bucket so it should be all good now.
Old Jun 10, 2008 | 10:31 PM
JP95ZM6's Avatar
I hope it's identical. Lower power does not mean you need less strength in the attachments. High stakes to gamble with flywheel attachment - those are the highest-stressed fasteners on your car, in shear anyway. Proper torque & locktite required, too.
Old Jun 10, 2008 | 11:45 PM
grade 8 bolt about the same length...should be fine.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
