Won't shify out of park!!
Old Jun 2, 2008 | 09:27 PM
Myxtreme1's Avatar
I bought a '94 Sunbird a few weeks ago for my daily beater. Well I am in the process of changing out the front hub assembly (d/s), I started the car and and tried to get it into gear and it seems to be stuck in Park! It feels like whatever triggers when you press the brake isn't functioning properly. I do have the caliper pulled off one side if that makes a difference. Is there something I can do? I can't think of anything I might have messed up while changing the hub assembly. Help!
Old Jun 2, 2008 | 10:19 PM
Green96Z's Avatar
I'm not sure about the Sunbird, but on an auto F-body there is a solenoid mounted on the gear selector shifter that prevents shifting unless the brake is depressed.
http://shbox.com/1/shifter.jpg
It's the black part at the top of the pic (the one with the orange clip on it).
Old Jun 2, 2008 | 10:39 PM
mdacton's Avatar
there is a shift interlock on it. there is something in the console you should be able to push and bypass it.
So many different cars without seeing it I couldn't tell you.
Old Jun 2, 2008 | 10:42 PM
Myxtreme1's Avatar
Thanks for the info guy, I will check into that stuff. I know I am not currently hearing the "click" when I push the brake in to be able to get it out of park.
Old Jun 3, 2008 | 08:05 AM
AL SS590 M6's Avatar
Moderator
Try turning the key to the first click only. This position is supposed to unlock the steering wheel and the shifter without having the power on or having to use the brakes.
If you can get it to shift that way then it's a problem with the brake interlock.
If it won't shift with the key in the first click then check to see if the shift **** is all the way down on the shaft. The keeper came out of mine once and the **** came up on the shaft enough that it wouldn't shift anymore.
KYWes
Sep 26, 2015 08:49 AM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
maverickmk
Sep 1, 2015 09:17 PM
