Flexplate to crank bolts keep coming loose.
Old May 17, 2008 | 06:34 AM
sharp396's Avatar
I have the TH-400 and am using arp flexplate to crank bolts. Going by my chiltons, and ARP directions, It says to torque them using moly. This is the 2nd time they have loosened. Could some bad vibrations be causing the to loosen or should I use a little medium strength loc-tite. I am also getting a lot of wheel hop, could this be due to the pinion angle not being set right or do I need lca relocation brackets? any help would be appreciated. thanks
Old May 20, 2008 | 12:20 PM
CANTONRACER's Avatar
I use and have always used red Loctite on my flex plate bolts.
Even with that, they still worked out some and everything was rattling really bad.
Do you have the dowel in the crank?
HectorM52
Jul 30, 2017 11:46 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
1LEThumper
Jul 14, 2003 12:45 PM
