Wont shift
Old Jun 7, 2008 | 10:15 PM
arctic white 94's Avatar
Wont shift
I am considering purchasing a 1997 gmc 1500 pickup with a 4l60e. The current owner says he was driving it and all of the sudden it would no longer shift. It was rebuilt roughly 100k miles ago. It still has first and reverse. I am not sure if the speedometer still worked or not(vss related). The ses light is on but I did not scan it. Does anyone know what the problem probably is. Would anything other than the vss cause it to completely quit shifting.
Any help will be greatly appreciated.
Old Jun 8, 2008 | 12:41 AM
Performabuilt's Avatar
Supporting Vendor
Need a scan that should set a code
Old Jun 8, 2008 | 07:28 AM
The current owner said he had it scanned and the only code was the egr valve. I do not have a scanner and until i already purchased the truck I probably wouldnt be able to get it scanned. Usually does the vss cause it to go out all at once or does this sound like a more serious problem.
Thanks for the help.
Old Jun 8, 2008 | 02:19 PM
Supporting Vendor
Well it will not change gears with a bad vss some cars will at very high rpm but that would be the first place to look but there should be a code for that.
I would purchase it with the price based on a bad trans and go from there.
Old Jun 8, 2008 | 06:03 PM
I will probably just pass on it because I really do not know how good everything else is. Thanks Performabuilt for the help.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
