Do I need Limited Slip Additvie?
Old Jul 21, 2008 | 10:57 AM
KITT3000's Avatar
I have a 1997 V6 with traction control. One wheel spins. I can't find anywhere in the maual that it says for me to put limited slip additive in the rearend.
Do I need to? If I don't, would it help if I did?
I have some rearend noise and I am doing this as a first step.
Thanks!
Old Jul 21, 2008 | 11:10 AM
km9v's Avatar
Traction control is not limited slip diff. Trac. control uses ABS. You may or may not have a LSD.
Old Jul 21, 2008 | 03:21 PM
KITT3000's Avatar
so I don't have to worry about the additive then right? What would happen if I put it in there?
Old Jul 21, 2008 | 03:34 PM
Probably nothing.
Old Jul 21, 2008 | 05:27 PM
Look at your RPO build code tag for G80. That would indicate you have a limited slip differential.
IndyZman
Oct 22, 2015 02:17 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
