To much atf?
To much atf?
just got mu CPT race 4l60e in and figured it would take 12 like it before. Put a quart in the converter and by the 10th quart it was coming out the over flow tube. Is this bad?
Nope havnt drove it yet, Just started it to let the fluid circulate thrught the lines and cooler, switched through all the gears. So how should I go about draing fluid?
Unless you have a drain plug in the transmission pan, you'll have to drop the pan to drain out the fluid. I've heard of people using a small siphon tube/pump down the dipstick tube, but I've never tried it...
88irocz28
03-27-2009 01:33 PM
