'Drill mod" Pix?
See, this is news too me, when i had ask about this awhile back (forgot to save the thread), i wasn't told anything about it only working on an LS1, its not that it doesn't shift good, just under higher RPMs, running through the gears at the track, it will sometimes just STOP in "N" when trying to shift fast too 3rd., sometimes its fine, i was told all it needed was the "Drill mod". The shifter is a B&M shorty, it feels tight, i'll look & see if anything is loose.
If you have problems shifting into 3rd, you probably have a bent 3-4 shift fork. It's a common problem with these trannies. Have it looked at. And yes, the drill mod is only for the LS1 hydraulics.
Where can i find Pix of the shift forks?
It could be a bent fork (upgrade to a steel 3-4 fork and put bronze pads on it and the 1-2 fork). It could also be the cheap stamped steel keys in the 3-4 slider. It is very common for a t56 to chew tham up and make it hard to go into gear. Get a new 3-4 slider, new blocker rings and a set of billit keys to put in the new 3-4 slider.
Here are a couple links:
http://www.gmhightechperformance.com...ild/index.html
http://www.noid.org/~lj/T56/T56.htm
slider
billit slider keys
3-4 steel fork
bronze pads
carbon blocker ring kit
You will need a quality set of knurled snap ring pliers, a custom long arm two jaw puller and a press.
Here is a link to the type of snap ring plier: knurled snap ring plier
Yes it has to come apart, but you can do it yourself with the right tools.
slider
billit slider keys
3-4 steel fork
bronze pads
slider
billit slider keys
3-4 steel fork
bronze pads
Yeah, thats what i was talking about, if i remember, you had to drill out the line itself, i heard it really helped with the 2-3 shift.
Victor Lamb
Aug 26, 2017 02:52 PM
Jul 10, 2015 02:23 PM
alex5366
Jun 7, 2015 08:50 AM
