clutches gone in my auto?
problem just surfaced
Drive normal up to using 7/8's throttle everything fine. WOT car goes to shift at top of rpm, revs up to limiter like its in neutral. Started in only the 1-2 gear change, now does it 1-2, and 2-3 under heavy and WOT. Checked in with scan tool. Tranny temp never went over 234 degree. Both solenoids worked. Converter locked and unlocked. Side note, sometimes manually down shifting to 1st, it would't deacellerate. I have a 2800 stall, and it was hyper teched before i bought it for higher shift points. Tranny has 169,000, and was track raced til summer nearly every friday night. I just want to make sure I have covered all my bases before rebuilding
carguyshu
Jan 22, 2017 11:19 AM
