need HELP ASAP - how to remove c-clip on axle
Old Jun 5, 2008 | 06:14 PM
jhthornley's Avatar
got axle seal leak on driver side..
car is in the air now.
wheel, rotor, diff cover are all off... fluid drained..
Axle won't come out.. (not bent). I read about removing c-clip... I pushed the axle in to max... but can't see "c-clip"..
read something about a "block". is that the bronze colored cylinder right between the two axles? It won't allow me to push the axle in any more.
How do I remove it? Do I remove it?
I've seen the c-clip on a past Ford van I owned... how far from the end of the axle will the c-clip be? I can see about 3/16" of axle next to that bronze colored cylinder.
Any/All help appreciated.
I did search, but came up w/ not much... off to shoebox's site to troll around.
thx
John T
Old Jun 5, 2008 | 07:09 PM
slowride94z's Avatar
its been a while since Ive done it but
you have to remove the cross pin first then the axle will go in further
the c clip is at the end of the axle may be 3/16"
a magnet retrieval tool works good to remove it
Old Jun 5, 2008 | 08:16 PM
jhthornley's Avatar
found it... axle is out. :-)
saw a "sticky" w/ diagram at the top of the drivetrain threads... thx for that..
bonehead move on my part was initially I'd put it up on ramps so I could easily drain the differential. Then I lift the driver's side rear so I can remove the wheel, brake caliper, rotor etc... good so far..
Then I read about the cross pin BUT... the 8mm bolt that holds it in is not visible... AND now my passenger side is on a ramp...
Had to put some boards under the jack and then put that side on jack stands too...
I was then finally able to spin the passenger wheel which in turn rotated the ring gear etc...
AND finally I was able to get the 8mm bolt that holds in the cross bolt...
so now I've got the axle out and am looking for a tool of mine to remove the seal and bearing from the axle tube end... typical... I can't find it. Will probably stop by advance and "rent" a tool???
Thought this was going to be a "slam dunk"... turning out to be a PITA..
Thx for the help tho... This site rocks. W/in reason I don't fear any jobs anymore, because there's always you guys to bounce questions off..
JT
Old Jun 6, 2008 | 07:01 AM
97FormulaWS-6's Avatar
Welcome to the world of working on cars... "everything" seems like a slam-dunk, but SOMETHING always gets in the way
Heathen1
Jan 2, 2016 04:27 PM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
