problem with drivers side rear axel on the 95 z28
Old Oct 18, 2005 | 09:37 PM
oneslowz28's Avatar
today i was changing the brakes on my 95 z28 a4 when i noticed that the drivers side rear axel had some play in it. with the rotor removed i can hold the axel by the studs and it will move in and out about 1/2 to 3/4 of an inch. the passenger side doesnt do this. I know this is not good. i know its not suspose to do this. I am a ase certified mechanic but drive train isnt my strongest point. Im thinking that maby its bad berrings or maby the retaining clip is not in correctaly. But if it is the retaining clip then wouldnt i be able to pull the whole axel out? like i said drive train isnt my strongest point by a long shot and this is the first time i have ever seen this type of problem.
Old Oct 18, 2005 | 10:41 PM
Re: problem with drivers side rear axel on the 95 z28
You might have an excessively worn c-clip or side gear. Bearing or axle wear would allow you to move the axle radially, not in/out.
Old Oct 19, 2005 | 04:00 AM
oneslowz28's Avatar
shoe box do u have the part number for the c clip?
Old Oct 19, 2005 | 08:06 AM
GM PART # 344171
Old Oct 19, 2005 | 02:09 PM
oneslowz28's Avatar
thanks rob
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
