Who has had a pressure plate come loose?
The car has a Spec Stage 2 in it with 14,000 miles on it. Flywheel was resurfaced at the time
Ok here are my symptoms:
1. Severe vibration around 2000 rpms whether in gear or not, clutch engaged or disengaged
2. More difficult to get into gear from a stop
3. Clutch does not grab as hard as it used to. Will not bark 2nd
4. Clutch seems to grab slightly higher in the pedal travel
Could the pressure plate have loosened up and cause these problems? If its not that does anyone else have an idea? Thanks
-Dan
-Dan
Re: Who has had a pressure plate come loose?
Is it possible to tighten the pressure plate with the transmission still in the car? I really dread having to pull the tranny to do this.
Yeah I kinda realized that you couldnt right after I made the post. I was thinking of the access plate that is in between the starter and flywheel.
Well as of right now the car is going to sit over the winter like this. I don't have the time or money to spend on it right now. Insurance is bad enough just on my Mustang. When I finally do get around to looking at it I'll probably just end up putting a new clutch in it anyway. No reason not to after going through all the trouble.
carguyshu
01-22-2017 11:19 AM
