M6 Problems
Old Oct 20, 2005 | 05:57 PM
98ztwiz's Avatar
M6 Problems
I'm having a problem with my 98Z. I can't get it to go into any gear at all. The only way I can get it into a gear is to shut the car off, put it in gear, then turn it on, other than that I cant even force it in(which I really dont want to do anyway). Also the clutch is real sloppy now, and when its pressed all the way to the floor its still engaged a little bit. My clutch seemed fine until this happened, and i wasnt screwing around when it did happen......Any ideas???? Thanks.
Old Oct 20, 2005 | 09:41 PM
CamaroBoy96Z28's Avatar
Re: M6 Problems
If the clutch is sloppy and wont go into gear, that sounds like the problem or the slave cylinder which is inside the bellhousing on your LS1 not engaging/disengaging the clutch correctly. Probably going to have to drop the trans and find out.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
