posi-trac or limited slip
Old Oct 1, 2005 | 04:15 AM
03Gluefactory's Avatar
I have a 1993 z28 withe the stock 3.23 gear ratios and I was wondering if it is posi-trac or limited slip. I have heard different things from different people and i was trying to find out if it's posi-trac without having to take the differential cover off.
Old Oct 1, 2005 | 05:47 AM
87DJP2001's Avatar
Re: posi-trac or limited slip
They are one and the same. Check your RPO codes and G80 will list Limited Slip Rear. Posi-Trac or Positraction was Chevolets trade name for a Limited Slip in the 60's and the nick name never went away.
Old Oct 2, 2005 | 10:38 PM
JonZ28SS's Avatar
Just an added question, both limited slip and posi-trac would both be basically one wheel normal movement right? My 96 SS has definitely has posi rear, both rear wheels spin at the same time. I also have a 94 3.4L and I think it has what you would call posi-trac, single right side movement, unless it slips, then traction switches to the left side. Both camaros have limited slip, but when they slip they both act different. I'd just like a further explanation as to the difference, if any, between posi, posi-trac, and limited slip.
Old Oct 2, 2005 | 10:53 PM
Read the first response..... "Posi-Traction" was a trade name that Chevrolet used back in the 1950's and 60's for a clutch-style limited slip differential. People shorted "Posi-Traction" to "Posi".
Posi-Traction = Posi = limited slip differential.
Pontiac called it "Safe-T-Trac", but that name never caught on.
GM had used a couple different types of limited slip units in the 4th Gens.... including a clutch type and the Torsen cone type, and maybe one or two others. SLP offered options for the differential in the SS, I believe.
Old Oct 5, 2005 | 06:57 AM
Z28_95RIDE's Avatar
Here's a link that proves helpful to GM owners.
http://www.drivetrain.com/GMtrkratio_posidata.html
Regards
Old Oct 5, 2005 | 07:43 AM
No, your 3.4 has a normal open differential with no posi.
Old Oct 5, 2005 | 12:28 PM
87DJP2001's Avatar
Just use the proper name Limited Slip rear and forget about calling it a Posi. Read some of the above Posts and see the dumb confusion.
Old Oct 5, 2005 | 12:46 PM
GM uses the terms interchangeably.
Right out of the Factory Service Manual:
G80 Axle, Rear Positraction (Limited Slip)
Old Oct 5, 2005 | 02:11 PM
87DJP2001's Avatar
3rd & 4th Gen cars....RPO G80 Limited Slip Rear. No recent useage of the term Posi-Traction by Chevolet Motor Div. Note: the word RECENT.
IndyZman
Oct 22, 2015 02:17 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
