M6 T56 6 Speed Transmission Leak.
Old Oct 16, 2005 | 07:11 PM
matt65's Avatar
Recent Transmission fluid on the ground may be related to this: About a week ago while doing a modified U-Turn I dropped the clutch pretty hard while in reverse. Of course I forgot about the traction switch and instead of tire spin I got a strong/ solid pulsing vibration and "Low Trac" light stayed on untill next restart.
Over the last week I have been leaking trans fluid on the pavement where I park, last night onto the Y-pipe and smoke. No mechanical change in operation in forward or reverse with the transmission. Been running great.
My questions are: What could be causing this? Are there any seals that I should replace? I have heard of the vent tubes blowing fluid at high RPM, can this be my cause? .......just looking for a fix.
Old Oct 16, 2005 | 07:17 PM
96TurboTA's Avatar
Re: M6 T56 6 Speed Transmission Leak.
Check the seal in the on the output shaft.
Old Oct 18, 2005 | 07:41 PM
matt65's Avatar
Any pics or procedures out there?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Timberwolf
Sep 2, 2002 10:42 AM
slothgrant
Aug 22, 2002 03:01 PM
