Can I do this on my LT1?
Old Sep 30, 2005 | 07:38 PM
SSConceptz's Avatar
If I take off the shifter on my LT1 Tranny (T-56) then can't I put the tranny fluid in that way instead of the pump which is so damn frustrating? I know how much so measuring isn't a prob. THanks
Old Sep 30, 2005 | 08:11 PM
OBE1 95Z28's Avatar
Re: Can I do this on my LT1?
Yes you can add you fluid through the shifter mounting hole but then you'll need to remove the shifter boot, shifter, scrap off the old RTV and apply new. Seems like it would be easier to pump the fluid.
Old Sep 30, 2005 | 08:13 PM
SSConceptz's Avatar
Well I've already got it off and you don't need RTV on the shifter plate, not much gets in there enough to make it leak. Never used it.
Old Sep 30, 2005 | 08:15 PM
SSConceptz's Avatar
Doesn't it take about 3 1/2 Qts of ATF?
Old Sep 30, 2005 | 08:30 PM
OBE1 95Z28's Avatar
I've added 3 3/4s quarts. Safest way is to remove the fill plug and fill it until it starts to come out; make sure the tranny is level.
Old Sep 30, 2005 | 08:42 PM
SSConceptz's Avatar
Yeah I knew that stuff but thanks for the info. Just making sure the shifter is a safe place to add. I just installed a new clutch after it blew off my new engine. Clutch separated (center and outside pieces)
Old Sep 30, 2005 | 11:23 PM
We have specific forums for specific topics...... "transmission" posts don't belong on "LT1/LT4 Engine Tech".
Moving to "Drivetrain"......
Old Oct 1, 2005 | 07:29 PM
lbrowne's Avatar
Dude, jack up the car, take off drain plug and drain.
Then place plug back in. Get an ample piece of garden hose that you don;t want to use again other than for this purpose - cut to your desired length, pop the hood of the car and drop one end down in there. Get underneath and stick the into the fill plug of the tranny.
Get out let car back down to ground level, stand by the engine bay, grab the other end of the hose, use a nice funnel with an end small enough to fit into the end of the hose - pour in the correct amount of tranny fluid.
Takes no time at all.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
