700r4 shift kit Q (cable going to TB)
Old Oct 1, 2005 | 07:46 PM
high c's Avatar
if i install a full manuwal shift kit into my 700 r4 witch im rebuilding now do i still need to run that cable (i forget its name) to the TB?
sorry about spelling
Old Oct 2, 2005 | 09:37 AM
12SCNDZ's Avatar
Re: 700r4 shift kit Q (cable going to TB)
It depends on the manual valve body manufactuerer. Some still use the cable, as where others don't. Your instructions should tell you rather you need it or not.
Frank
Old Oct 2, 2005 | 06:06 PM
high c's Avatar
im going to use the stock valve body and use one of the top of the line transgo shift kits, ill have to do some reading and find out if i need it or not
Old Oct 2, 2005 | 09:26 PM
smoknta's Avatar
Some kits can still be used as auto shifting if left in drive, so the cable will be needed. Or some will make them all the time full manual. Just do you homework and make sure you get what you want.
Old Oct 3, 2005 | 05:34 AM
Pro Built Automatics's Avatar
Use the TV cable when using the Trans-Go Performance Shift kit, and set it to the maximum TV pressure at WOT. If you have any questions on this, call me at 909 7951876 after 10am PST.
Old Oct 3, 2005 | 04:30 PM
high c's Avatar
thanks for the info man, if i need help ill give you a call
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
TrouserSnake
Aug 7, 2002 12:43 PM
DarkHorse
Aug 1, 2002 04:59 PM
