quick question about gears
Old Sep 19, 2005 | 08:39 PM
chrp3rd's Avatar
car is a 96 formula ws6 with the cones auburn Ive got 3.73 and I bought a set of motive 4.10s installer says make sure that they are a thicker gear or ill have to get a 4 series carrier some one said that slp sell the little spacers but he thought that if they are the motive gears then im fine and I can go ahead a install them. please any help getting married in 2 weeks and need the car thanks
Old Sep 20, 2005 | 11:47 AM
sssalah's Avatar
Re: quick question about gears
Never knew there was a 4 series carrier for the 10 bolt, you have a 3 series carrier which will be fine with 4.10.
Old Sep 20, 2005 | 12:20 PM
Dnsean's Avatar
ive heard that you should only go up to 3.73 in a 10bolt, too much stress on internals with 4.10
Old Sep 20, 2005 | 02:32 PM
importeater's Avatar
Exactly, I have 4.11's on a stock 3 series carrier.
Old Sep 20, 2005 | 03:38 PM
93LT1355's Avatar
Not saying that you are wrong but with 4.10's you have more teeth to turn so it takes less power to rotate them wouldn't that be less stress?
Old Sep 20, 2005 | 04:54 PM
boosted-lt1's Avatar
The higher the ratio...the thiner the ring...I believe.
-Scott.
Old Sep 21, 2005 | 08:39 AM
Dnsean's Avatar
lets just say, make sure if you do put them on, go easy on it for a while... or boom, the teeth on the ring will go and crack in a big place
Old Sep 21, 2005 | 12:11 PM
-Scott.
3.42, 3.73 and 4.10 are all the same ring gear, 41 teeth. Pinion is 12, 11 and 10, that being the difference.
Not sure about that one because they are also seeing more torque at a lower speed because of the higher RPM's. Thats a question for those guys on here that hurt my brain when I read their posts.
Craig
Old Sep 22, 2005 | 12:59 PM
Fat_Boy's Avatar
Craig
I know what your talking about!!!!
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
